Fast Intake + Evap?
Old Dec 20, 2010 | 11:38 PM
Phiber Optik's Avatar
Phiber Optik
Default Fast Intake + Evap?
For those of you with a FAST intake, how did you connect the evap control to the manifold? The nipple is there beside the throttle body, and I assume I should hook it back up, but my 92mm intake doesn't have the mounting provisions for the valve that the stock LS1 intake does... Any suggestions?
Old Dec 21, 2010 | 07:44 AM
vettenuts's Avatar
vettenuts
I found mine rested nicely with the wire harness and simply used a tie wrap to hold it to the harness. I didn't crank on the tie wrap, just snugged it.
