Liquid filled pressure gauge question
Dec 21, 2010 | 12:13 AM
This is probably a stupid question, but I accidently spilled some of the liquid out of my liquid filled fuel pressure gauge.
Is this going to impact its accuracy at all? It's still 3/4 filled. I just didn't know if it had be to have a precise amount down to the mL in there or not
Dec 21, 2010 | 12:31 AM
No the thick liquid is just in there to dampen vibration
Dec 21, 2010 | 01:11 AM
just make sure that the gauge is vented. A sealed chamber will expand and contract with alt. and temp. greatly affecting the acuracy.
Dec 21, 2010 | 01:24 AM
How can it be vented and sealed?
Dec 21, 2010 | 04:15 AM
Quote:
Originally Posted by
Milan
Good question. All the ones I've ever seen have an air pocket inside to begin with, to allow for temp changes I would presume.
Dec 21, 2010 | 08:47 AM
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Phiber Optik
The thick liquid in the gauge is clear glycerin, which is used only to dampen the needle vibration.
It does not affect the accuracy of the gauge.
Dec 21, 2010 | 09:38 AM
Cool so if a little spilled out it's not going to be a big deal.
Dec 21, 2010 | 09:42 AM
No. If a little spilled it is not a big deal. There should be a small bubble in the liquid anyway for expansion, contraction and temp changge.
Dec 21, 2010 | 02:11 PM
All the liquid filled gauges we use on our vacuum systems have a small tit on the rubber fill plug. Before we cut the tit off, the 0-30" HG. gauges are reading 5-8". After we vent them, they are 0". Loosing some of the liquid is bo biggie in fact you can drain them and they read the same.
