Cleaning Vortex - Any tips?
Old Apr 8, 2002 | 10:58 AM
Y2K+1 Vette's Avatar
Y2K+1 Vette
Default Cleaning Vortex - Any tips?
I need to clean my Vortex filter and was wondering if there are any tips, tricks, etc. regarding removal or cleaning which may help. Thanks. :D
Old Apr 8, 2002 | 12:43 PM
Tormania's Avatar
Tormania
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Cleaning Vortex - Any tips? (Y2K+1 Vette)
I don't know of any tricks, for mine I end up having to remove the entire airbox and the bridge up to the intake manifold. Kind of a pain but I've done it a few times now so it's not that big a deal anymore.
Old Apr 8, 2002 | 01:42 PM
97C5ENVY's Avatar
97C5ENVY
Default Re: Cleaning Vortex - Any tips? (Tormania)
Be sure to use the K&N recharge kit(cleaner and oil). Spray the cleaner on the outside of the filter, let it sit for about 10 minutes then wash with a hose from the inside......this pushes the dirt back out of the filter opposed to pushing it deeper in. Let it air dry, then re-oil and re-install.
Old Apr 8, 2002 | 01:52 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: Cleaning Vortex - Any tips? (97C5ENVY)
How often are you guys cleaning yours?
Old Apr 9, 2002 | 12:38 AM
AlphaKnight34's Avatar
AlphaKnight34
Default Re: Cleaning Vortex - Any tips? (rschiltz)
I didn't have to take the whole airbox off. All I needed to do was loosen the clamp at the top of the airbox, reach under the car up to the filter and pull it down and out......Seems a lot easier than taking the box off. :cool:
Old Apr 9, 2002 | 10:30 AM
97C5ENVY's Avatar
97C5ENVY
Default Re: Cleaning Vortex - Any tips? (AlphaKnight34)
Yeah but is your car slammed?
rschiltz - I clean my filter once a year or every 4K miles.....which ever comes first (mine's not a daily driver). ;)
[Modified by 97C5ENVY, 8:31 AM 4/9/2002]
Old Apr 9, 2002 | 10:39 AM
Y2K+1 Vette
97C5ENVY - sorry, but I'm missing the point, what do you mean with "Yeah but is your car slammed" ?
Old Apr 9, 2002 | 10:47 AM
0-60-IN-5's Avatar
0-60-IN-5
I agree with AlphaKnight34. It is not necessary to remove the whole thing...just unscrew the clamp and reach underneath to pull it out. :yesnod:
I usually clean mine about every 15-20k...this is the recommended from BPP. :flag
0-60-IN-5
yellowy2kc5's Avatar
yellowy2kc5
Slammed=lowered, i.e. a lowered car would be harder to reach under is what I would assume was meant :)
Old Apr 9, 2002 | 11:03 AM
97C5ENVY's Avatar
97C5ENVY
Since my car is slammed (and alot of others are lowered) it makes it REALLY difficult to get up under the front bumper. To give you a better idea, my front scrape guard (the black thingy that hangs down from the front bumper) is only 2.25" off the ground.
Old Apr 9, 2002 | 11:16 AM
Y2K+1 Vette
Cleaning Vortex - Any tips? (Y2K+1 Vette) (97C5ENVY)
quote from 97C5ENVY:
"Since my car is slammed (and alot of others are lowered) it makes it REALLY difficult to get up under the front bumper. To give you a better idea, my front scrape guard (the black thingy that hangs down from the front bumper) is only 2.25" off the ground."
ok, gotcha. It's not a problem for me, I have the benefit of being able to use a lift to get under the car. it sounds like I won't have to take the box off, which is what I was hoping for. Thanks for the info.
:chevy
Old Apr 9, 2002 | 09:37 PM
MySea6's Avatar
MySea6
Default Re: Cleaning Vortex - Any tips? (Buckmaster)
Just don't over oil the filter after cleaning!
What he said ^ Don't over oil the filter :cheers:
Old Apr 9, 2002 | 10:47 PM
jschindler's Avatar
jschindler
Default Re: Cleaning Vortex - Any tips? (MySea5)
Sounds like good advice, but hard to quantify. Does K & N still make the oil in the aerosol can? (I still have one about 20 years old - doubt if it still works).
Old Apr 10, 2002 | 02:41 PM
MySea6's Avatar
MySea6
Default Re: Cleaning Vortex - Any tips? (jschindler)
It is hard to describe how much oil to use. With the spray (yes it is still available), I make one quick pass along the length of the pleat. Let the oil wick into the filter for ten to twenty minutes. Then repeat covering any uncoated spots. Uncoated spots should show up white or close to it.
I have used the squeeze bottle also. Same procedure but it seems to wick in a bit slower. Idea is to get a thin even coat of oil on the filter. The red dye helps a great deal.
In past years, prior to MAF's, I did not worry as much about too much oil. I don't think those little bastich wires in our C5 MAF's like to be coated with oil and bet the DIC will tell us so. :cheers:
To Cleaning Vortex - Any tips?
