Trouble getting into reverse
Old Dec 24, 2010 | 09:38 PM
sgtzim's Avatar
sgtzim
St. Jude Donor '11
Default Trouble getting into reverse
I have a 2004 C5 coupe - manual transmission, with about 72,000 miles. No modifications except the deletion of the skip shift.
A couple days ago I started to have a lot of difficulty getting the car to shift into reverse. It feels almost like there is a barrier that will not allow me to push the gear shift over to the right. I can get into all other gears fine, but really have to lean into it to force it over to reverse.
I had the transmission fluid changed about 5,000 miles ago and have had no issue.
Is there something I can do to remedy this or do I need to get a shop to look at it? Or, will it go away once the weather gets warmer or something? I've never experienced this short of issue before.
Thanks for any help.
Old Dec 25, 2010 | 03:54 PM
ragtopws6's Avatar
ragtopws6
It is most likely your reverse lockout solenoid or lack of power to it. I would first check for power at the connector with the key on. If you have power, you have a bad solenoid.
The solenoid is located on the top of the "doghouse" cover on the pass side.
Old Dec 26, 2010 | 02:10 PM
sgtzim's Avatar
sgtzim
St. Jude Donor '11
thanks for the input -- checking electrical stuff is probably beyond my ability, but I'll give it a shot -- who knows, I might get lucky (otherwise I'll have to take it to the shop)
Old Dec 26, 2010 | 02:28 PM
DaBoz's Avatar
DaBoz
Mine has been that way since day one... I just put it in neutral, put the clutch in and out and then it goes in easily...
Old Dec 27, 2010 | 07:17 AM
Scubanme's Avatar
Scubanme
Sounds like the reverse lock-out solenoid.
Old Dec 27, 2010 | 04:13 PM
JJ 86's Avatar
JJ 86
Does anyone have a part # for the solenoid?
Old Dec 27, 2010 | 06:57 PM
gmccreary's Avatar
gmccreary
Could be one of the tabs has broken off and gotten stuck. There's 12 of them in there and I broke 7. Spec Stage 1 installed this week.
To Trouble getting into reverse
