Alignment specs.??
Old Apr 8, 2002 | 01:19 PM
Maineiac's Avatar
Maineiac
From: Making my carbon footprint as BIG as possible
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude '03-'04-'05-'06
Default Alignment specs.??
Can anyone with a service manual provide the alignment specs. for a 2001 Vert.? Thanks. :seeya :seeya
Old Apr 9, 2002 | 06:25 AM
Maineiac's Avatar
Maineiac
Default Re: Alignment specs.?? (Maineiac)
:confused: :seeya
Old Apr 9, 2002 | 05:23 PM
Brian Madderom's Avatar
Brian Madderom
VBP has specs in their new catalog which they've tested.
Daily driver: Advanced street:
Toe - 1/32"in Toe - 0 to 1/32"in
front= Camber - 0 Camber - 1/4"neg
Caster - 6-7 pos Caster - 6-7 pos
Toe - 1/16"in Toe - 1/16"in
rear= Camber - 0 Camber - 1/2 neg
:cheers:
Old Apr 9, 2002 | 07:01 PM
Maineiac's Avatar
Maineiac
Default Re: Alignment specs.?? (Brian Madderom)
:cheers:
Thanks buddy! :cheers: :seeya :seeya :D
Old Apr 10, 2002 | 11:47 AM
lostsoulny's Avatar
lostsoulny
is this different than a normal street car alignment specs? for example if I went into my tire shop and just said give me a 4 wheel alignment, would they need these specs or are they standard ? :confused:
Old Apr 10, 2002 | 02:02 PM
Brian Madderom
Default Re: Alignment specs.?? (lostsoulny)
Yes, they are a little different. The engineers and race teams that work with VBP has come up with these specs to minimise tire wear and improve handling. :flag
Old Apr 10, 2002 | 05:03 PM
MySea6's Avatar
MySea6
C5 Wheel Alignment Specifications
RPO Operation Service Preferred Tolerance
Front Alignment Specifications
All Front Individual Toe 0.04 +/- 0.10
All Front Sum Toe 0.08 +/- 0.20
All Steering Wheel Angle 0 +/- 1.0
FE1 & FE3 Front Individual Caster 7.4 +/- 0.5
FE1 & FE3 Front Cross Caster Within +/- 0.5 --
FE1 & FE3 Front Individual Camber -0.2 +/- 0.5
FE1 & FE3 Front Cross Camber Within +/-0.5 --
FE4 (Z06) Front Individual Caster 6.9 +/- 0.5
FE4 (Z06) Front Cross Caster Within +/- 0.5 --
FE4 (Z06) Front Individual Camber -0.7 +/- 0.5
FE4 (Z06) Front Cross Camber Within +/- 0.5 --
Rear Alignment Specifications
All Rear Individual Toe -0.01 +/- 0.10
All Rear Sum Toe -0.02 +/- 0.20
All Rear Thrust Angle 0 +/- 0.10
FE1 & FE3 Rear Individual Camber -0.18 +/- 0.5
FE1 & FE3 Rear Cross Camber Within +/- 0.5 --
FE4 (Z06) Rear Individual Camber -0.68 +/- 0.5
FE4 (Z06) Rear Cross Camber Within +/- 0.5 --
Old Apr 10, 2002 | 05:10 PM
Diego M's Avatar
Diego M
:confused: :seeya
:seeya :p: :seeya
To Alignment specs.??
