Using Front Calipers on Rears???
Old Apr 8, 2002 | 01:28 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Using Front Calipers on Rears
This thread (Rotor Discoloration) got me thinking as I just ordered these....
So is anyone running front calipers in the rear?
Would they work with the new 14" 2 piece eradispeeds?
Does anyone have the proecure to the conversion?
Old Apr 8, 2002 | 02:28 PM
Patman36's Avatar
Patman36
Default Re: Using Front Calipers on Rears (Mean Green 2000)
You probably know this already but I heard the only problem is that you would have to make a braket and relocate the parking brake mechanism on the rear. Hope that helps :cheers:
Patrick :D
Old Apr 8, 2002 | 02:57 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: Using Front Calipers on Rears (Patman36)
I'm definitely not a "bracket fabricating" kinda guy.....hopefully someone out there has a templete or insrtuctions on how they did theirs :)
thanks :cheers:
Old Apr 8, 2002 | 03:40 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
this could be interesting...those rear just look too small..
Old Apr 8, 2002 | 04:16 PM
pjazz's Avatar
pjazz
C6 of Year Winner (performance mods) 2019
Default Re: Using Front Calipers on Rears (Grumpy)
If you do a search on this someone already did this. From what I've seen and heard the emergency brake is inside the rotor.
Old Apr 8, 2002 | 04:26 PM
chuckster's Avatar
chuckster
Mark, I have had my rotors and calipers off. I can tell you this. The Caliper Bracket is EXACTLY the same for the front as it is for the rear. that being said means that the front calipers WILL Fit on the rear Caliber Brackets. Now you need a bigger surface for the larger diameter front brake pads. I guess that another set of front rotors would fit on the back. If you did this you would loose the parking brake.
This is all theory based on one fact. That the caliper brackets are the same. So mounting the Calipers is not the issue.
It would be worth a try while you have your car apart. Did you get the Calipers powder coated yet?
Old Apr 8, 2002 | 04:34 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: Using Front Calipers on Rears (chuckster)
not yet....back and forth between that and regular painting :D :crazy:
Old Apr 8, 2002 | 04:48 PM
RoliO's Avatar
RoliO
I'm not 100% sure, but I think LGM has this bracket you need. Call Lou and ask him. :cheers:
Old Apr 8, 2002 | 04:55 PM
MAGRED 02's Avatar
MAGRED 02
This would be interesting if it is not too difficult to do. Please let us know what you find.
:cheers:
Old Apr 8, 2002 | 05:03 PM
Lawdogg's Avatar
Lawdogg
Active Streak: 90 Days
Default Re: Using Front Calipers on Rears (MAGRED 02)
DRM has been doing that conversion. I don't know the specifics, but you will lose the parking brake.
Old Apr 8, 2002 | 05:05 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: Using Front Calipers on Rears (Rippied Z06)
I'll look into the DRM site....thanks guys :cheers:
some out there has to be running this setup :D
Old Apr 8, 2002 | 07:12 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
well I checked out DRM and LG's websites and couldn't find any info....
Old Apr 8, 2002 | 08:16 PM
Arnie's Avatar
Arnie
Cruise-In II Veteran
Xtreme has a set up to use the front calipers on the rear http://www.xmotorsports.com
Old Apr 8, 2002 | 08:21 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: Using Front Calipers on Rears (Arnie's C5)
rockin' :D :cheers:
Old Apr 8, 2002 | 08:25 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
damn....I was hoping for something costing a little less $.....I'll have to call and talk to Nate and see what we can work out....I already have the brakes, just need the brackets, etc :D
Old Apr 8, 2002 | 10:22 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
anyone else :)
Old Apr 8, 2002 | 10:32 PM
gpflepsen's Avatar
gpflepsen
What's this do to the brake bias of the rears? I'd think the rears would be clamping down more due to the larger piston surface area. Might throw some curve ***** at you when hauling it down on that twisted off-ramp.
To Using Front Calipers on Rears???
Old Apr 9, 2002 | 08:26 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: Using Front Calipers on Rears (gpflepsen)
thanks Gerry that's why I was hoping to talk to someone who's done this mod :D
Old Apr 9, 2002 | 09:41 AM
QuicksilverC5's Avatar
QuicksilverC5
Personally, I would be nervous about upsetting the 'balance/proportionality' of the overall brake system. If the differences in the calipers were only 'cosmetic', then obviously this wouldn't matter but I'm not sure that's the only difference.
I wonder if someone at the FACTORY could be contacted for advice?
Old Apr 9, 2002 | 10:00 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: Using Front Calipers on Rears (QuicksilverC5)
good idea, not that I have contacts that I can just ring up :D.....I'm also gonna be talking to Nate about the setup he has :D
