lpmayo
Old Dec 28, 2010 | 03:28 PM
lp mayo's Avatar
lp mayo
2nd Gear
Default lpmayo
I have a 20001 c5,whose healights popup when I start the car. They stay up for sometime then drop without use of the switch. However they work fine when using the switch. I've changed out the switch assb, but it still occurs.
Old Dec 28, 2010 | 03:54 PM
oh1vette's Avatar
oh1vette
Does it happen when you start in a garage and they go up and then pull out and they go down?
Old Dec 28, 2010 | 04:15 PM
lucky131969's Avatar
lucky131969
Wouldn't that be a drag, if he replaced the MFS, and the twilight sentinel is turned on....
Old Dec 28, 2010 | 04:59 PM
dougbfresh's Avatar
dougbfresh
Check this 1st. Read the owners manual if you don't know what this means.
Old Dec 28, 2010 | 10:13 PM
BumbleZ's Avatar
BumbleZ
Default Was Your Car Originally Sold in Canada
I think the ones sold in Canada don't let you disable the twilight sentinal.
To lpmayo
