Hayden fan controller
Old Dec 29, 2010 | 05:24 PM
TOPCATHR's Avatar
TOPCATHR
Default Hayden fan controller
I was thinking of installing a fan controller to get the cooling fans to go on at a lower temp. Am i inviting problems due to the fact that the car was designed to run hotter than many other cars? I have a 1998 vert and was wondering what you guys and gals might think......thanks
Old Dec 30, 2010 | 05:36 AM
Wolfmanjohn's Avatar
Wolfmanjohn
Intake screen, too.
My '04 runs no hotter than any of my other cars, and I don't think it was designed to, either.
Old Dec 31, 2010 | 04:17 PM
TOPCATHR's Avatar
TOPCATHR
They do run hotter than most cars . Thats why there are so many requests for info about the hight temps. The main reply is that its nothing to worry about because the cars run higher than others normally.
Old Jan 1, 2011 | 02:49 AM
rmarks's Avatar
rmarks
Gee - I thought the coolant temp was mainly controlled by the thermostat?
Old Jan 1, 2011 | 12:11 PM
TOPCATHR's Avatar
TOPCATHR
The thermostat dictates when the coolant from the block enters the radiator. Changing to a 160 thermostat does not mean the the engine will get no hotter than 160 degrees. It only means that the coolant will enter the radiator at that temp. The 180 degree thermostat allows the coolant to stay in the block till it reaches 180 degrees and so on.. There is a vast amount of info on this forum and everytime i do a search i learn more... Happy new year to all..........
To Hayden fan controller
