C5 Lowering reversal
Old Dec 29, 2010 | 10:14 PM
monsterms's Avatar
monsterms
Default C5 Lowering reversal
Just picked up a C5 that is lowered, but car rides like a rock. Will reversing the lowered vehicle improve the cars ride? And if it will how do you go about reversing the lowered chassis?
Old Dec 29, 2010 | 10:18 PM
Simonmcnasty's Avatar
Simonmcnasty
Just tighten back up your bolts, you will need to find a good flat surface to that you can measure wheel well gaps to get it all evened back out.
Old Dec 29, 2010 | 10:23 PM
monsterms's Avatar
monsterms
I assume what your saying is the ride will improve? It really looks good lowered but the ride is atrocious. It will jolt your kidneys.
Old Dec 29, 2010 | 10:41 PM
Simonmcnasty
I can't tell you if your ride will improve, but thats how you raise it back up. Only you will be able to determine if it suits your needs at that point.
My Z is slammed and I have no complaints about the ride at all, not harsh in the least , in my opinion, but I hear lots of complaints about lowered Z's riding harsh, I assume its all in the expectation of the owner.
Old Dec 29, 2010 | 10:45 PM
monsterms's Avatar
monsterms
Thanks for the input.
Old Dec 29, 2010 | 11:14 PM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
Some will post up a formula asking you measure 3 distances, but I just played with the bolts/nuts until it was even. The ride quality will improve some, but I recommend you upgrade/replace the shocks as the stockers were probably damaged at the lowered height.
Old Dec 30, 2010 | 01:32 AM
MN-Brent's Avatar
MN-Brent
You might be able to improve your ride as is by working over the shock bumpstops.
See thread: http://forums.corvetteforum.com/c5-t...ng-the-c5.html
Old Dec 31, 2010 | 12:35 PM
lwise4's Avatar
lwise4
I have a nasty driveway and the Z06 I bought was lowered. I raised it up and I just counted the top threads and made sure that they were the same all around.
This did not change the ride as far as I can tell but it did help a little with the driveway.
To C5 Lowering reversal
