Ran Codes: Need Help ON Traction Control/ABS Problem
Old Dec 30, 2010 | 12:39 PM
ndirishr1's Avatar
ndirishr1
Default Ran Codes: Need Help ON Traction Control/ABS Problem
As suggested on my last post I ran codes on the DIC and got the following:
28-TCS C1214H C
99-HVAC B0361H
AO-LDCM B2282H
B2284H
A1-RDCM B2283H
B2285H
B2265H
If anyone can help me determine what these codes mean and what I can do to fix them it would be greatly appreciated. Is there a way to clear these to see if they come back up or do they clear themselves automatically when the problem is fixed or both? This is a 2001 A4 convertible. Has BPP induction, long tube headers, 4.10 gears.
Old Dec 30, 2010 | 12:58 PM
lucky131969's Avatar
lucky131969
28-TCS C1214H C
99-HVAC B0361H
AO-LDCM B2282H
B2284H
A1-RDCM B2283H
B2285H
B2265H
Unfortunately, the 1214 code means the EBCM is toast. Since you've been a member for 8 years, I assume you know how to use the search function. Search for C1214......plenty of reading.
Old Dec 30, 2010 | 01:07 PM
dougbfresh's Avatar
dougbfresh
www.absfixer.com
Old Dec 30, 2010 | 08:35 PM
ndirishr1's Avatar
ndirishr1
Any comments on the other error codes? Can anyone tell me how to erase the codes after they are read to see which come back?
Old Dec 30, 2010 | 09:05 PM
dougbfresh's Avatar
dougbfresh
Just clear them from the DIC.
Old Dec 30, 2010 | 10:02 PM
JUSTAKAR's Avatar
JUSTAKAR
Plenty of info in the sticky at the start or top of the section, the codes except the failed ABS will reset as thay are all history codes suffix (H) the other (C) current will not reset. The car can be drven with care when you send the dry portion of the abs to absfixer...... as stated above who will fix the abs module ...just cover the ABS portion with a 3mm plastic and ty wrap it while your ABS is being fixed....Remember you have no ABS or nannies helping you while it is out. cost is <200 bucks including shipping.
To reset these history codes
With the key on and hold the option button down and press the fuel button 4 times. This will display codes and tell you the what code it is. You can also clear the codes by holding the reset button down until the codes clear.
hth Ian
To Ran Codes: Need Help ON Traction Control/ABS Problem
