Side Window Upgrade
Old Jan 3, 2011 | 08:30 AM
M109R's Avatar
M109R
2nd Gear
Default Side Window Upgrade
Is there an upgrade for 1998 side windows so they go up and down that little bit like newer ones before door opens? Ruining my convertible top edging
Old Jan 3, 2011 | 09:47 AM
dougbfresh's Avatar
dougbfresh
Adjust your top/window so it doesn't rub.
Old Jan 3, 2011 | 12:25 PM
Cratecruncher's Avatar
Cratecruncher
With door upholstery trim off, speaker assembly out and moisture barrier removed you can adjust the travel height of the window. Lower the window halfway down so you can see the regulator guides through the openings. The screw adjusters are on the guides where they clamp to the glass. Sorry, I don't know jack about vert tops.
Old Jan 3, 2011 | 12:44 PM
65GGvert's Avatar
65GGvert
Here's how to adjust your top to clear the window.
http://www.c5forum.com/cgi-bin/ultim...ic/1/2213.html
Old Jan 3, 2011 | 04:47 PM
M109R's Avatar
M109R
2nd Gear
Thanks,,, will try that on the first nice day,, thanks
Rick
To Side Window Upgrade
