Popping on starting
and am experiencing a "pop" upon starting the car. It only "pops" once then starts and runs as normal no other symptoms. Anyone got any idea what the cause maybe ????
My experience would say that a "pop" is an ignition misfire-- IF it only happens at start-up I would guess that you have a leaky injector that loads up one cylinder and when started it tries to fire off all that excess fuel all at once causing a misfire--then it clears up quickly--
Try using some good injector cleaner I like Seafoam the best--next would be Chevron in the blue botttle---
PS : at 44K new plugs are absolutely needed---if youve never changed them this could be all it needs too---
