First, let me say this. I am sure this has been asked but I searched for over an hour and couldn't find anything.
I do NOT have to change my clutch or slave but I do have to pull the tranny out because I believe I have a bad synchro (often times have problem going into second).
Do I have to pull the whole drivetrain with torque tube and all to take out the tranny or can can just pull the rear carrier out and disconnect the torque tube?
Thanks in advance and sorry for what I believe is a repeat question.
Actually, it's easier pulling/installing the assembly...IMO.
Ok, thank you very much. I am about ready to do that. Spent a little time this afternoon getting all the preliminary stuff done assuming I was going to pull it. But then I started to second guess myself.
When I swapped my trans, I was doing a clutch anyway so I had the torque tube out. You could probably leave the torque tube in but no matter what, make sure the engine is supported so you don't let it hit the firewall and crack all the stuff of the back.
You could leave the torque tube. You'd have to disconnect the shifter rod from the shifter base so you can pull it out. Either way is about the same work but I've found that it's much easier to get the torque tube back into the clutch by itself.
This is the easiest way since I have done this job more than anyone I know.
-Remove the shifter and remove the 30 Torx holding the shifter base from the shifter rod.
-Remove the parking brake lines/ABS sensor harness both sides
-Remove the 2 18mm bolts holding the upper control arms/both sides
-Remove the 2 13mm shock bolts/both sides
-Remove 4 21mm rear cradle nuts (make sure to do this by hand and NOT power tools)
-Remove the 2 15mm caliper bolts on both sides and hang the calipers so they don't hang by the brake lines
-Remove the axle shafts on both sides
-Lower the rear cradle
-The TT will rest on the belly pan so it doesn't need to be supported
-You can remove the harness connectors to the trans
-Remove 8 13mm bolts from trans to TT bell
-You can remove the trans/diff together
If you follow the steps above, you don't need to remove the exaust, TT or anything else.
That makes alot more sense to me.
A couple of years ago, I asked on the tech forum in regards to switching out the diff .
I had recieved several posts recommending pulling t/tube & all the rest in one pull. That it would be easier that way.
I appreciated the advise but I decided to just pull the cradle & then the diff.
