reverse lockout wiring
Old Jan 11, 2011 | 06:36 PM
pat-b's Avatar
pat-b
Default reverse lockout wiring
Can someone post the complet electrical system to the reverse lockout sylinoid.... spelling... I know. Thanks
Old Jan 11, 2011 | 09:19 PM
rehirsch8's Avatar
rehirsch8
Here you go. See the attached file.
File Type: pdf
Old Jan 12, 2011 | 10:06 PM
pat-b's Avatar
pat-b
thanks, skip shift not working, this should help
Old Jan 14, 2011 | 09:39 PM
pat-b's Avatar
pat-b
the under hood fuse keeps poping.. seems as if ill need a new cylinoid. Any one have one?
Old Jan 15, 2011 | 10:32 AM
rehirsch8's Avatar
rehirsch8
There are quite a few posts on replacing the solenoid. I got a used one last summer from RPM Transmissions. You can get a new one through GMPartsHouse.com.
I would put a post on the forum describing the fuse problem you are having. That fuse handles several components in the drivetrain and there may be some other parts you want to check.
When does the fuse blow?
Old Jan 15, 2011 | 10:46 AM
pat-b's Avatar
pat-b
Fuse blow instantly when ignition is turned. I only have the wiring diagram from above. What else is attached to the same fuse?
Old Jan 15, 2011 | 11:01 AM
rehirsch8's Avatar
rehirsch8
I don't have my diagrams with me so I can't look it up. I believe the fuse wire splits out using splice packs to several other switches and sensors related to telling the PCM that the car is ready to start.
My guess is that if you disconnect the reverse solenoid (it's a pain to get at but it can be disconnected), the fuse will still blow.
I won't be back until Monday evening so you may get a faster response if you post the fuse blow problem more broadly on the forum.
Old Sep 3, 2014 | 11:19 PM
The Highlander's Avatar
The Highlander
Anyone solve this?
To reverse lockout wiring
