4l60e or 4l65e
Old Jan 15, 2011 | 11:32 AM
timritchieblue's Avatar
timritchieblue
Default 4l60e or 4l65e
has anyone ever tried the 4l65e trans? in a c5
Old Jan 15, 2011 | 04:26 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Similar transmission just beefed up, however they don't have the correct outer shell to work in a vette.
Most of the beefed up 4160's have the improved 4165 parts in them.
Old Jan 15, 2011 | 04:30 PM
timritchieblue
what about a 2005 vette? its a 4l65e? it should bolt in? i need a new tranny, i can get a 2005 c6 tranns for the same price as a c5 tranny? i just want it beefier
Old Jan 15, 2011 | 04:39 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I'm not sure they are the same. Different pumps, torque converters, etc ...
Personally, I would give RPM a call in Indiana if you going to try doing this.
By the way the 4160 and 4165 end up in the same place with modifications.
Old Jan 15, 2011 | 05:40 PM
timritchieblue
i sent them a email? just waitin to talk with them,, im swapin the tranns, rear and stall, since my tranny went. big project for me. i think i can do the install? it doesnt look to hard?
Old Jan 16, 2011 | 08:04 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Just a messy job, while you're there you might want to check the inner torque tube to make sure your couplers are still good. They tend to dry rot over the years and fall apart.
Automatics are pretty easy to do. Make sure you line up the spline shaft inside the bell housing (engine) so that you can remove the spline lock (10MM) hex.
Drop the rear cradle and support the tranny. Drain the fluids, remove the tranny cooling lines.
Hook up a tranny jack, lower slowly disconnect the shifter cables and wiring harness.
Unbolt TT from the front bell housing and slide it out. Takes a few hours.
Do not use a air gun ever on the cradle bolts.
Old Jan 16, 2011 | 11:50 AM
timritchieblue
thanks for the reply, wish someone could confirm a 2005 4l65e trans would bolt up? im trying to do research, but having very little luck
Old Jan 16, 2011 | 11:58 AM
lucky131969's Avatar
lucky131969
As already suggested, perhaps a call to RPM Transmissions, will yield an expert opinion.
Old Jan 16, 2011 | 12:07 PM
corvettebob1's Avatar
corvettebob1
Don't waste your time trying to get a 4l65E to work in your car the mount location is different.
Just get a level V from RPM it'll have 4l65 guts and more in fact way more then you need at your power level.
Where your at a level IV is still overkill but it will give you room to grow.
Old Jan 16, 2011 | 12:48 PM
clif's Avatar
clif
St. Jude Donor '09-'10
I have a 4L65E tranny in my 99 vert. It came from RPM transmissions. It is the stage 6.
Old Jan 24, 2011 | 07:00 PM
timritchieblue
found a local shop for the job
http://www.redlineper.com/
going with a transmission specialties converter
http://transmission-specialties.com/...roducts_id=824
To 4l60e or 4l65e
