LS6 Intake...Hype!!!
Old Apr 10, 2002 | 01:02 AM
Myhardtop's Avatar
0Myhardtop
Former Vendor
Default LS6 Intake...Hype!!!
I was offered an LS6 intake installed for $500 flat by a local shop. The car turned 362hp and 355tq with shorty headers
LoudMouth, Vortex, after market Cam and stock heads. Question: will the LS6 intake give me any considerable HP gains
with my current mods and if so, what!!! Is it worth it!!! Please help, this is a limited time offer. :D :D
Old Apr 10, 2002 | 01:14 AM
Crushinator's Avatar
Crushinator
Default Re: LS6 Intake...Hype!!! (Myhardtop)
Sounds like a decent deal to me. You'll probably going about 5 horsepower. Not much, but it all adds up.
Old Apr 10, 2002 | 01:29 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: LS6 Intake...Hype!!! (QuickSilver97)
:yesnod:
vetterdstr :cheers:
Old Apr 10, 2002 | 01:36 AM
vettvert's Avatar
vettvert
I am a believer. I went from 365 RWHP to 390 RWHP just with the addition of the LS6 intake and NGK Copper spark plugs.
Old Apr 10, 2002 | 01:51 AM
RCswish's Avatar
RCswish
Default Re: LS6 Intake...Hype!!! (vettvert)
:eek: Wow, your head/cam job must have been begging for air. From what I read, the LS6 manifold is only a must do mod after a head/cam job.
Old Apr 10, 2002 | 01:56 AM
vettvert's Avatar
vettvert
Default Re: LS6 Intake...Hype!!! (RCswish)
:eek: Wow, your head/cam job must have been begging for air. From what I read, the LS6 manifold is only a must do mod after a head/cam job.[/QUOTE]
I believe so. The car was running fairly rich before we did the intake, so I believe that the intake balanced the air/fuel ratio substantially. After doing the dyno at The Vette Doctors, Carmen told me not to do a thing to the car, that it was the strongest running heads/cam car with an A4 tranny that he has done.
Old Apr 10, 2002 | 05:37 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
I thought you had news for us....not asking a question....
Old Apr 10, 2002 | 01:09 PM
Iboomalot's Avatar
Iboomalot
I gained 7-8 rhp after a direct swap and before and after dyno runs. You might get more due to cam and I tested directly after the swap thus no computer learning was done.
Old Apr 10, 2002 | 01:21 PM
chuckster's Avatar
chuckster
Default Re: LS6 Intake...Hype!!! (Mean Green 2000)
So did I. :rolleyes:
Old Apr 10, 2002 | 01:56 PM
EHS's Avatar
EHS
Default Re: LS6 Intake...Hype!!! (chuckster)
I've done this modification and I can add some....Input!!!
Old Apr 10, 2002 | 02:07 PM
nevadacoin's Avatar
nevadacoin
hmmmmmmmmmm. :rolleyes:
Old Apr 10, 2002 | 07:21 PM
EHS's Avatar
EHS
Default Re: LS6 Intake...Hype!!! (nevadacoin)
mhhhhhhhhhhhhhhhhhhhh. :rolleyes:
Old Apr 10, 2002 | 07:30 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: LS6 Intake...Hype!!! (EHS)
let's try and keep it on topic guys ;) :cheers:
well....do tell :D
Old Apr 11, 2002 | 12:11 AM
turboo2u's Avatar
turboo2u
Other than some ponies gained, what you will feel with the LS-6 intake is increased and better throttle response in a car with stock heads and cam. I had this mod done last week and can't believe how sharp the throttle is now. With just your average bolt-ons, 6th gear feels very much like 5th!
Old Apr 11, 2002 | 12:26 AM
cmb396's Avatar
cmb396
CI 7-8-9-10 Veteran
Default Re: LS6 Intake...Hype!!! (turboo2u)
I read in a post the other day that the 01-02 Ls1 and Ls6 intakes are the same... is this true? I saw this in the 4sale section where L.A.P.D replied to some one. Let me know... :cheers:
Old Apr 12, 2002 | 09:22 AM
C54FUN's Avatar
C54FUN
St. Jude Donor '03-'05-'06-'08-'10
Default Re: LS6 Intake...Hype!!! (cmb396)
I too installed one last week "with a set of headers" and can say the delivery of power is much smoother and responsive (3500-5500RPM). I did dyno and got some interesting numbers....an improvement to the previous baseline as follows: 18 RWHP (334HP) and 14 Ft/ Lbs. of Peak Torque (344)..got 18-20 Ft. Lbs at 4-5500 RPM! Mine is a bsically stock motor. While this gain is not all the credit of the intake, it isn't bad for a bolt-on kind of thing. Will test these numbers at the next Challenge. BTW got my '02 Z06 Intake from SLP for $399. and the headers were FLP's (one of the first 25 for $1299.). Took 4 hrs. for both installs.
Joe
[Modified by C54FUN, 7:25 AM 4/12/2002]
Old Apr 12, 2002 | 01:34 PM
Nate@CorvetteGarage's Avatar
Nate@CorvetteGarage
Supporting Vendor
Cruise-In I Veteran
St. Jude Contributor '04
We dynoed the LS6 manifold on a 2000 car and the gains were real. The customer had a Donaldson Blackwing and Borla exhuast for mods. The swap yielded 17hp and 13lbs of torque to the rear wheels. Not too bad! Driveability and response is better too!
Nate
To LS6 Intake...Hype!!!
Old Apr 12, 2002 | 01:46 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: LS6 Intake...Hype!!! (Nate@xtreme)
Nate
:eek: I would definatly place that increase in the unique catagory.
What were the before and after numbers?
Old Apr 12, 2002 | 02:02 PM
shockwave's Avatar
shockwave
Nate
Sorry about being a "Doubting Thomas" but if a 2000 is able to get that much of a gain then why do the 2001 LS1's only have a 5 hp gain when all 2001's have this intake from the factory? The 2000 LS1 is rated at 345 hp and the 2001-2002 are rated at 350 HP. What accounts for this difference? I can understand a modified car breathing better with the better intake, but only an intake mod and exhaust mod showing such gains is surprising...
Old Apr 26, 2002 | 11:20 PM
VettemanC5's Avatar
VettemanC5
Default Re: LS6 Intake...Hype!!! (shockwave)
I too am curious about an LS6 intake. But to chime in on the question of why the 2001 only gains 5 hp from it and Nate's test vehicle gained nearly 17 hp from it might I suggest that the pairing of the LS6 intake along with the Donaldson Blackwing might yield greater results than the pairing of the LS6 intake and the factory air box. Just a suggestion. :confused: \
Also I'm sure the Borla exhaust might have helped a little. Just clearing out the bottle necks in the flow of things. :cheers:
