AntiTheft column lock HELP!!!
Old Jan 18, 2011 | 08:40 AM
C5Mang's Avatar
C5Mang
6th Gear
Default AntiTheft column lock HELP!!!
I have a 2002 C5--steering column lock bypass relay installed (twice). Still shuts down fuel pump frequently. Anyone know how I can disable this completely? Very frustrated. Also, BCM has been replaced as well.
Old Jan 18, 2011 | 09:06 AM
dougbfresh's Avatar
dougbfresh
The 2mph shutoff has to be programmed out
Old Jan 18, 2011 | 09:54 AM
C5Mang's Avatar
C5Mang
6th Gear
Will a chevrolet dealer do that or do I need to purchase a Tech2 or something similar? Thanks for your help.
Old Jan 18, 2011 | 09:57 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
well where are you loacted perhaps someone local can help you
Old Jan 18, 2011 | 09:59 AM
pewter99's Avatar
pewter99
Largo?
Old Jan 18, 2011 | 10:02 AM
pewter99's Avatar
pewter99
I know someone who can help if you are in the area
Old Jan 18, 2011 | 10:06 AM
pewter99's Avatar
pewter99
I sent you a PM...call me
Old Jan 18, 2011 | 10:32 AM
C5Mang's Avatar
C5Mang
6th Gear
I live in St. Petersburg Florida--I have pulled the lock out and replaced it with the relay override.
C5Mang's Avatar
C5Mang
6th Gear
Where do I retrieve messages? I am new as of this morning to this site. Thanks.
Old Jan 18, 2011 | 10:38 AM
C5Mang's Avatar
C5Mang
6th Gear
I have unplugged the column lock and replaced it with a relay bypass. The fuel pump shuts off intermittenly upon startup. Sometimes I will also get a service ABS/TCS light, but very rarely.
Old Jan 18, 2011 | 11:52 AM
pewter99's Avatar
pewter99
Nice talking to you earlier...hope you get this resolved soon.
Old Jan 18, 2011 | 03:15 PM
lucky131969's Avatar
lucky131969
If the fuel pump shuts off after start up, that is NOT a column lock problem. Even if you did have a security issue, the PCM would disable the fuel injectors, not the pump. Behavior consistent with the 2mph shutoff issue, requires you to put the car in gear, and attempt to move...then it shuts down.
Old Jan 18, 2011 | 05:35 PM
C5Mang's Avatar
C5Mang
6th Gear
Thanks brother, I appreciate the help very much.
To AntiTheft column lock HELP!!!
