trying to get low!
Old Jan 18, 2011 | 09:32 PM
jake higdon!!!!'s Avatar
jake higdon!!!!
Default trying to get low!
im trying to lower my 98 c5 and ive got the rear dropped but the front two bolts are not turning they are a lil rusty but any body have an idea how to brake them loose? impact wrench? how strong are the bolts ?
Old Jan 18, 2011 | 10:22 PM
jrose7004's Avatar
jrose7004
Hose them down with Liquid Wrench.
Old Jan 18, 2011 | 10:24 PM
Dennis Wilson's Avatar
Dennis Wilson
Did you lift the end of the spring to relieve the pressure on the bolts?
Old Jan 18, 2011 | 11:03 PM
m6 c5's Avatar
m6 c5
I personally tried everything and nothing worked for me...
Old Jan 19, 2011 | 07:54 PM
jake higdon!!!!
yeah i tried everything just cant figure anything out!
Old Jan 19, 2011 | 09:04 PM
Slow Z06's Avatar
Slow Z06
liquid wrench over night, following day use a large vise grip on the pad side of the bolt. Be sure the spring has no pressure on the bolt or it will not move
Old Jan 19, 2011 | 09:11 PM
Z0600's Avatar
Z0600
If the bolts are seized then try and find areo kroil. It's the best penetrating oil that I have used and that's what they use at caterpillar dealerships. They have tried them all and stuck with that for a lot of years. Hope you get that thing lowered, they look damn good that way
Old Jan 19, 2011 | 09:18 PM
Blue-Z's Avatar
Blue-Z
I also sprayed WD40 on the control arm where the rubber contacts the arm. It will get under there beleive it or not and makes it alot easier to turn once you get the bolt freed up!
To trying to get low!
