Shifter Woes
Old Jan 20, 2011 | 10:57 PM
defconfire's Avatar
defconfire
Default Shifter Woes
I seem to have an interesting problem. I'm having problems with shifting at low RPMs. It feels like there is a slight crunch on engagement usually on the 1-2 shift or the 3-4 shift the crunch not audible but it can be felt in the shifter.
Downshifts are perfectly smooth and at higher RPM shifts i have never had a problem with it.
I have played with the shifter alignment countless times to no avail.
If any one has any suggestions it would be much appreciated.
Old Jan 20, 2011 | 11:04 PM
ALLEGRO's Avatar
ALLEGRO
You may have an issue with your clutch master cylinder not disengaging the pressure plate.
What year and how many miles?
Old Jan 20, 2011 | 11:11 PM
defconfire's Avatar
defconfire
It's a 2002 Z06 with 55k miles.
I haven't ruled that out yet, I'm not sure what kind of symptoms I'd see. I have regularly changed my clutch fluid though.
Also I forgot to mention the Trans is an RPM Stage IV. I had an issue with the aluminum 4th shift fork when I got it.
Old Jan 21, 2011 | 12:36 AM
defconfire's Avatar
defconfire
I also tried changed the trans fluid which didn't seem to make any real difference.
Old Jan 21, 2011 | 03:31 PM
schnellTTZ06's Avatar
schnellTTZ06
Sounds like the clutch isnt fully disengaging. Bleed it out really good. I hope you have a remote bleeder.
Old Jan 21, 2011 | 04:44 PM
defconfire's Avatar
defconfire
I'll definitely look into it. Flush the clutch fluid out and see if it helps. I really wish i had a remote bleeder now lol.
Old Jan 21, 2011 | 05:07 PM
skyavonee's Avatar
skyavonee
Doesn't sound too abnormal to me. Is this something that just started to happen all of a sudden, as if someone flipped a switch, or has it gradually reached its current state?
If the clutch isn't fully disengaging I would expect your "crunch" to be audible. I'm not sure though.
You mentioned you have a RPM transmission - are your shifter and clutch stock?
Old Jan 21, 2011 | 05:50 PM
defconfire's Avatar
defconfire
It is the stock shifter and the stock clutch. I think it has gotten worse progressively, or possibly I just notice it more now.
To Shifter Woes
