Pullys
Old Jan 23, 2011 | 07:36 PM
lavery48's Avatar
lavery48
Default Pullys
Is there any possiable way that the Harmonic balancer pullys could move back toward the engine? My A/C belt broke and I was looking at the pullys and they didn't seem to line up.They all felt tight so I don't know what's going on.
Old Jan 23, 2011 | 08:03 PM
lucky131969's Avatar
lucky131969
Yes it is, if the balancer separates. Post a pic.
Old Jan 23, 2011 | 08:49 PM
00Corvette's Avatar
00Corvette
It's a fairly common issue. you can also put a marker or paint line on the balancer straight from the hub to the outer part...go drive the car and get on it once or twice up to 5000 rpm or so...see if your outer line moved relative to the inner. then you'll know if it's spinning on the hub(forgive the grammar/spelling/punctuation)
Old Jan 23, 2011 | 09:38 PM
Paul 75 L82's Avatar
Paul 75 L82
I'm just finishing a cam install and I will tell you changing the balancer is a little work. Everyone needs to find the joy in removing your steering rack. Oh, and 240 torque on that balancer bolt.
Old Jan 23, 2011 | 10:04 PM
bucketlist1957's Avatar
bucketlist1957
Default Pulley
You need to replace it before it gets all the way back and eats things up. There was a post on here recently about one wearing into the oil pan to the point it had to be replaced.
Old Jan 23, 2011 | 10:27 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
That is not the correct torque value for the harmonic balancer bolt. It's torque to yield fastener with in initial torque value (can't remember) in FT/LBS for the first pass followed by a second pass to 140 deg I believe.
Old Jan 23, 2011 | 10:35 PM
lucky131969
FP at 37 ft lbs, then 140 degrees. If he used an ARP bolt, 240 ft lbs, is what most have reported using........although, ARP suggest the following depending on the lube:
196 ft lbs - moly lube
235 ft lbs - loctite
247 ft lbs - 30 wt oil
Old Jan 23, 2011 | 10:47 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
Thanks but he did not specify ARP. I would not use a non-TTY fastener for this application unless there was a key way used.
Old Jan 24, 2011 | 08:50 AM
lavery48's Avatar
lavery48
Thanks folks, I figured it might have moved. I had one come apart once on another car. Did someone say I would have to take down the steering rack?
Old Jan 24, 2011 | 08:30 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
Yes, it is one of the required steps listed in the service manual procedure for the harmonic balance replacement. You may want to consider getting one.
To Pullys
