tube regulator vacuum
Old Jan 23, 2011 | 09:21 PM
LisaJohn's Avatar
LisaJohn
St. Jude Donor '10
Default tube regulator vacuum
What does it do? Mine is broken.
L
Old Jan 23, 2011 | 09:26 PM
lucky131969's Avatar
lucky131969
L
vacuum line to the fuel pressure regulator?
Old Jan 23, 2011 | 09:47 PM
LisaJohn's Avatar
LisaJohn
St. Jude Donor '10
The GM parts diagram I looked at called it tube regulator vacuum. We changed the oil, removed the air filter, and blew the debris out between the condenser and radiator yesterday. I noticed that the small tubing was broken in half where it comes out from the left side engine cover. Just wondered what it does. I don't know how long it's been broken. I'll order a new one this week. Thanks!
L
Old Jan 24, 2011 | 12:06 PM
corvettebob1's Avatar
corvettebob1
It adjusts fuel pressure according to vacuum in front of the throttle body.
Running with it off or broken will have a slight effect on fuel economy by making the engine run slightly rich.
Old Jan 24, 2011 | 05:23 PM
LisaJohn's Avatar
LisaJohn
St. Jude Donor '10
Thank you! So it's ok to drive until I can get a new one?
Lisa
Old Jan 25, 2011 | 11:54 AM
corvettebob1
Lisa
Old Jan 25, 2011 | 08:17 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You can go to autozone and get a Nylon vacuum line repair kit to repair that line. It has a small sleave inside the kit and you can just mend the nylon line.
Old Jan 25, 2011 | 08:34 PM
LisaJohn's Avatar
LisaJohn
St. Jude Donor '10
Thank you!
To tube regulator vacuum
