TT input shaft question
Old Jan 24, 2011 | 06:21 PM
nickolbag's Avatar
nickolbag
Default TT input shaft question
I just want to to make sure a 99 input shaft will fit in a newer TT. I have a 99 but put in a 02 z06 TT. A pilot bearing chewed up my input shaft and the only replacement I could find is from a 99. I was told the input shafts were the same thru the years. Before I buy it I just want to double check.
Old Jan 24, 2011 | 06:57 PM
bumble-z's Avatar
bumble-z
Send (Rick) ragtopws6 a pm. I'm thinking it would be the same. He would know for sure.
Old Jan 24, 2011 | 07:09 PM
mAydAy121's Avatar
mAydAy121
St. Jude Donor '10
It will be different where it bolts to the torque tube, 10mm vs 12mm coupler
Old Jan 25, 2011 | 06:13 PM
nickolbag's Avatar
nickolbag
So I cant use an input shaft off a 10mm TT if I have a 12mm TT?
To TT input shaft question
