weiand intake ?
Old Jan 24, 2011 | 10:03 PM
jake higdon!!!!'s Avatar
jake higdon!!!!
Default weiand intake ?
i found i weiand aluminam intake for 350 bucks on craigslist. are they worth anything? any power increases from an intake?
Old Jan 24, 2011 | 11:21 PM
C.Davis's Avatar
C.Davis
A lot of people dislike aluminum intakes like weiand and bbk because of heat soak..
They are cheaper though and no2 guys like them incase of a big backfire..
$350 isnt real low. there is a ls1tech sponsor that sells bbk for 400 new weiand is a little more..
on ls1tech there is also a dyno comparison that showed a bbk had a few HP over the ls6
Old Jan 25, 2011 | 02:46 AM
manley845's Avatar
manley845
I bought a brand new BBK intake for under $400 last fall.
They do not heat soak. Please research the phenomena. Don't just take the advice of individuals that haven't even used aluminum intakes. My intake has never been too hot to touch after long hard trips, the fuel rail is ALWAYS cold after a drive, and I personally have never noticed any negative effects since installing the aluminum intake. In short, heat-soak is primarily an issue with carburetor equipped engines.
If you have an LS6 intake already, the only real difference you will notice is the appearance under the hood. I had an LS6 intake and only changed to BBK because I want my engine to look like an engine.
If you have an LS1 intake, either intake you go with may get you about 5-10hp on the top end, which probably won't be noticed by SOTP.
Let us know what you do.
Oh, here's a couple pics (not the greatest angles though)
Old Jan 25, 2011 | 08:31 AM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
What ever happened to the composite intake they were promising???
Old Jan 25, 2011 | 09:23 AM
dougbfresh's Avatar
dougbfresh
With GM's track record w/ composite intakes-I think I would trust an Aluminum intake more. GM even went back to Aluminum on some engines (like the 3800) after many problems with the composite ones leaking.
Old Jan 25, 2011 | 12:10 PM
jake higdon!!!!
okay i was just trying to get an idea if 350$ was a good deal or not. ill shop around but i really like the polished look as far as intake goes! anybody now where i can find a good intake at used possibly for a good deal? or maybe even new for under 4 or 5
Old Jan 25, 2011 | 01:55 PM
Quick Silver Z
Sorry, I was refering to the Weiand composite intake that was once much more than a rumor.
http://forums.corvetteforum.com/c5-g...or-update.html
Old Jan 25, 2011 | 02:03 PM
TheWildcat's Avatar
TheWildcat
$350 isnt really a deal $250 is... John
Old Jan 25, 2011 | 03:01 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
I love my Weiand!
So many angles, it all glitters
Old Jan 25, 2011 | 06:11 PM
jake higdon!!!!
Originally Posted by ~Joshua
I love my Weiand!
GIMMIE!!
To weiand intake ?
