Engine pull, top or bottom?
Old Jan 25, 2011 | 08:41 PM
lavery48's Avatar
lavery48
Default Engine pull, top or bottom?
I've got to pull my engine on '98. Do I need to pull it out through the hood opening or out through the bottom of the car??
Old Jan 25, 2011 | 08:46 PM
TheWildcat's Avatar
TheWildcat
all depends on if you have a lift. I dont so mine go out through the top..John
Old Jan 25, 2011 | 09:07 PM
fsuforever's Avatar
fsuforever
I was in the same boat,didn't have a lift so I had to pull it from the top ,if u have a 2 post lift drop it from the bottom
Old Jan 25, 2011 | 09:34 PM
Slow Z06's Avatar
Slow Z06
top here
Old Jan 25, 2011 | 09:54 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Cajundude did a full write up on pulling from the top. I am swapping the motor in my 98 and I am undecided on wether I want to throw it on a borrowed lift or just do it in the garage with my engine hoist.
Old Jan 26, 2011 | 12:50 PM
ZZOOM06's Avatar
ZZOOM06
If you have access to a 2 post lift then by all means take it out the bottom!
Jimbo
Old Jan 26, 2011 | 02:04 PM
Fastguy's Avatar
Fastguy
The only downside is that I need to tow the car an hour north, pull the engine, and swap mine in a day since it will be a borrowed lift. If I do it in my garage, I can do it at my own pace whenever I feel like it.
To Engine pull, top or bottom?
