LS6 intake vs FAST
Old Apr 22, 2012 | 10:42 AM
ctusser's Avatar
ctusser
Originally Posted by Silnus
good flowing heads need better flowing intake than the LS6. Usually, if your wanting to make over 460 rwhp on stock cubes all motor, you'll need a FAST. Best results are Tony Mamo's ported FASTs. Crazy power up top, you'll lose just a tad down low.
You could get that with the TPIS modded LS6. Lingenfelter tested the TPIS LS6 on a 575 hp motor and was only 4hp off a FAST 90 at peak but had better low-mid range. The FAST will ultimately have more potential though depending how far one goes.
Old Apr 22, 2012 | 02:29 PM
v84life's Avatar
v84life
I got mine in I put the pcv hose up above the map sensor and turned the spliter to contour the firewall that gave me a little more room its tight but its in place just fine didnt have to push it back in there with a fork lift or anything so I think it will be fine, I had to super glue the map sensor in though.
