has anyone had any experience fitting an after market radiator in a c5? Did you take pics of your fab/install???
Call me crazy, but I'm not a fan of dropping 550 bucks for an upgraded radiator, when I see nice radiators that are the right dimensions, but not direct fit for 275 or so
Not sure what you mean by aftermarket, but I have the DeWitts that required a minor mod to the fan shroud but otherwise dropped in. Most of the modification was required due to the optional oil cooler I had built into the radiator.
I did the same swap as Vettenuts, using the Dewitts with the left side oil cooler built in. Easy swap, fits perfectly once you trim the fan shroud, and well worth what it costs.
Do your self a favor and get a DeWitts or Ron Davis unit. The install is easy, they are specifically designed for our cars and everything fits correctly. You can get an aftermarket unit that is "CLOSE" in size, but you will end up fabricating / modifying brackets, shrouds, hose routing, etc. In my opinion, it is not worth saving + or - $250 and having to do all that work to make it fit correctly. My time is worth more than that.
Jimbo
Best are some of the best mod you will do to the car. The stock one is crap to this one...
Hey Tom I had a customer call in and order a supercharger. I have caller Id so I see the name or organization and so I get this call and its from a Tom DeWitt...LOL I thought it was you calling to yell at me or something...hahahahah small world we live in
I have a blown 8 rib forged 402 and ever since I put the supercharger on it I couldn't run the a/c as the engine would overheat (in hot weather). Put in a DeWitt's with no transmission cooler (I put the largest B&M cooler I could fit for the transmission). Heat problem solved.
I believe the DeWitt has 50% more cooling capacity than stock. One can see by the pic it is comparing apples to oranges.
