Need TPSM help or guidance
Old Jan 28, 2011 | 10:49 AM
thehdman's Avatar
thehdman
Default Need TPSM help or guidance
I just bought a 97 C5 and the diagnostic center says the TPSM needs service. I was hoping to bypass or shut this off but have been told either fix or put up with the message. Its annoying so I need to fix it. From what I have read the batteries seem to be a problem and can be replaced on this year. What I need is input with anyone who has dealt with this. Is it easy to change the batteries and has that been the problem most of the time? Or should i just replace the whole sensor? Either way is there some who supports this forum a vendor(s) that offer realistic prices on the parts? Any help would be appreciated.
Old Jan 28, 2011 | 10:50 AM
jrose7004's Avatar
jrose7004
Forum member Corvette Don will replace them for you. Or you can buy new ones www.gmpartshouse.com
Old Jan 28, 2011 | 11:47 AM
dmarkshark's Avatar
dmarkshark
If I were you I would first try to resync them to see if they work. When I bought my 99 this summer, I had the same issue, took a speaker magnet and went around and resync'd the sensors. They still work at this time. Easy to check and a lot cheaper if it works, if not they can be rebuilt as stated above or new ones, which are expensive.
Old Jan 28, 2011 | 01:12 PM
thehdman's Avatar
thehdman
Thanks to the both of you for the advice. Will try the resync first, nothing to lose there.
Old Jan 28, 2011 | 05:05 PM
thehdman's Avatar
thehdman
thanks this helps a lot
Old Jan 28, 2011 | 06:01 PM
Redvette_22's Avatar
Redvette_22
You might try Dorman to see if they sell them, I know they have them for the later C5's.
My buddy did my 98 TPMS with new batteries and they worked until and after I sold the car.
To Need TPSM help or guidance
