Advice needed in dealing with a shop
With the clutch pedal depressed, the torque tube shaft no longer rotates. Now there is relative rotation between the TT input shaft and the pilot bearing and the slave cylinder release bearing. The release bearing is now riding against the pressure plate diaphragm spring actuating fingers. If the noise is most pronounced with the clutch pedal depressed, the release bearing and or the pilot bearing are your most likeky causes for the noise.
I use the term most likely because you will not be able to determine the actual problem until the drive line is dropped and a visual inspection reveals the failed component. Good luck.
BTW what type of clutch did the shop install?
Noise is NOT good!! Have them drop the inspection plate and see if you can localize the noise better. Sounds like there not going to be very helpful. Let us know how it turns out.BC
http://www.drivetrain.com/parts_cata...wers_here.html
If the problem is noise coming from the clutch system, a simple test can identify the source of the noise before you tear into the system. There are two potential bearing-noise makers in the clutch system-the release bearing and the pilot bearing. To determine which one, if either, is making the noise follow these steps:
Step 1 With the engine running and the transmission in neutral, if the noise occurs it is in the transmission, most likely the front bearing supporting the input shaft.
Step 2 If that is not the problem, place your foot on the clutch pedal and begin to depress the pedal. If you begin to hear the noise at this point, the problem is the clutch release bearing. If not, proceed to the next step.
Step 3 Push the clutch pedal all the way to the floor. If you hear the noise at this point it is the pilot bearing or bushing. If you do not hear any noise during this test, the problem is not in the clutch system. Identifying these conditions early before removing and replacing the components goes a long way toward preventing a recurrence of the problem.
Thanks,
Sam
I would consider small claims court but, you will have to build a case to prove they were negligent. Go talk to them with the evidence/smoking gun and see what they have to remedy the problem.
Thanks,
Sam
Does your original paperwork (bill) from the first shop show that they replaced the pilot bearing ?
Did you take pictures showing that is was installed incorrectly ?
Is the mechanic who made the repair willing to go to court and testify on your behalf ?
If you have all (3) of the above evidential items, you might be able to win your case. Without it, you don't have a chance.
Yes and NO!
This is what I can tell you. I took a woman to Small Claims Court for damaging my 02 ZO6. The case was accepted. When its accepted, it is PUBLIC DOMAIN.
When it goes public, Peoples Court, Judge Judy, Judge Joe Brown and any other TV show court will contact you and see if you want to have the case adjudicated on the TV Court show.
IF,,,,, you feel that the the shop will NEVER pay you, the TV Show is a way to get your money back.
IF,, you have a bullet proof case and you feel that the shop will honor the judgment if you win, take the county court circuit.
BC
Peter
