Twilight delay?
Old Jan 29, 2011 | 11:25 AM
TomWoodgeard's Avatar
TomWoodgeard
St. Jude Donor '12
Default Twilight delay?
Hello everyone; New to C5 Vettes, have had 3 older models in the past. I'm still trying to figure out some things.
On the twlight option, what is the delay for? Turning lights on after startup? Turning them off when it gets daylight?
Currently, If I'm parked in the carport, start the enging, the lights come on instantly, I drive off, and the lights don't go off for at least a minute, sometimes 4 or 5
Help????
Thank you....Tom Woodgeard
Old Jan 29, 2011 | 12:31 PM
oh1vette's Avatar
oh1vette
Have a look:
http://forums.corvetteforum.com/c5-t...-them-off.html
Old Jan 29, 2011 | 01:40 PM
DeeGee's Avatar
DeeGee
Twilight (Optional in United States,
Standard in Canada)
Press the OPTIONS button until TWILIGHT - OFF
appears on the display, then use the RESET button to
page through the following selections:
TWILIGHT - ON
TWILIGHT - OFF
If you choose TWILIGHT - ON, press the OPTIONS
button again to display DELAY TIME 1 2 in the DIC.
Use the OPTIONS button to switch between delay time
1 and 2. You can increase the delay time by pressing
button 1 (1 FUEL) or decrease the time by pressing
button 2 (2 GAGES). Each bar is equal to 12 seconds
Old Jan 30, 2011 | 01:13 PM
ALLEGRO's Avatar
ALLEGRO
I turned this OFF because my AE is stored in the garage each night. I see no reason to have the headlight motors operate each morning as I go to work.
Given all the problems of worn gears in these motors, I just don't see the need in cycling them so often.
To Twilight delay?
