stock heads.
Old Jan 30, 2011 | 09:33 PM
jake higdon!!!!'s Avatar
jake higdon!!!!
Default stock heads.
can i make any power by buying a set of stock heads for my
ls1 and get them worked? what kind of power can be made by doing this and also would i be better off buying a set of other LS heads that would fit on my car? what kind f power could be made by doing this?
Old Jan 31, 2011 | 06:58 AM
crainholio's Avatar
crainholio
Originally Posted by jake higdon!!!!
can i make any power by buying a set of stock heads for my ls1 and get them worked?
Yes jake higdon!!!!!!!!!
Very few people upgrade only the heads, a cam is usually in the plan jake higdon!!!!!!!!!!!!!!!
400+ hp at the wheels is pretty much cookbook recipe with the right cam and a decent set of heads jake higdon!!!!!!!!!!!!!!!!!!!!!!!
Old Jan 31, 2011 | 07:33 AM
AU N EGL's Avatar
AU N EGL
stock LS1 heads really dont flow very much above a 550 cam lift.
So going with ported 243 heads and cam would help
Old Jan 31, 2011 | 10:35 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Find/buy a set of 243 castings (LS6 or LS2) . Great platform to build from and low cost.
Old Jan 31, 2011 | 07:23 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Worked 241 heads flow great. Worked 243 heads flow better. Both drop off after .600 lift.
It's all about your budget. Back in the day people would build LS 427s with 241 heads.
You will need a cam that works with what ever heads you decide to go with.
I have a set of 241 heads for sale if you're interested. Stock.
Good luck with your goals.
Old Jan 31, 2011 | 07:25 PM
jake higdon!!!!
crainholio!!!!!!!!!!!!!!cranholio!!!!!! cranholio!!!!!!!!!!!
Old Jan 31, 2011 | 07:40 PM
kjmj's Avatar
kjmj
I put on a set of p&p 5.3 heads and made 400+ through an A4. I just posted in general last night if you want the info.
Old Jan 31, 2011 | 08:04 PM
-98-z28-darkness-'s Avatar
-98-z28-darkness-
going heads only is not the most cost effective method for power. decent worked heads will be $500+ and you need to tune.
my brother made about 410hp to the wheels on is 98 ls1 Camaro with a cam, stock 241 heads with new springs about $350, and tune.
Old Jan 31, 2011 | 08:14 PM
jake higdon!!!!
im sure that a head swap is not the best way to gain more power but i think heads would be a lot easier than a cam swap. ive never tried a cam on a pre assembled motor. i guess im just scared to mess it up . would it be something anyone could do when heads are changed?
Old Feb 4, 2011 | 09:05 PM
crainholio's Avatar
crainholio
Less posting, more reading. Check ls1howto.com to get an idea of what's involved in either a cam-only swap or a head swap...cam is much easier than heads.
Old Feb 4, 2011 | 09:27 PM
lucky131969's Avatar
lucky131969
Nope.
Old Feb 4, 2011 | 10:08 PM
crainholio's Avatar
crainholio
Do not make my bunghole angry...
To stock heads.
