im going to replace my fuel filter 2mro. it has about 50k miles on it. where can i get an adapter for a fuel pressure gauge to hook up to the fuel rail so i an check?
An auto parts store. Most fuel pressure gauges come with adapters, to be used on various models.
Ok guys my father had a fuel pressure gauge. With the car running there was about 58 psi of fuel pressure. With the car off there was 54 psi.
I don't know for sure but that sounds like the correct pressure at least with the car running...wait for lucky or one of the other senior member to post back up before you buy the new pump bro.
Donnie
checked battery voltage? Alternator voltage? Loose cable? Just curious about these items. You also mentioned that it has been 50k with the fuel filter. Have you done a recent tune up?
Tip: Disconnect the crossover at both ends. This allows the tank (left) to drop far enough to disconnect the hoses inside the crossover, then tank removal.
Even though they are "press fit" they don't give up easily.
The joke was on me though as I got one of the tanks with the opening too small to just pull the pump out.
Dremel fixed that!
That's what I do....whenever something get's in my way, I just use a dremel
yea the fuel filter needs to be replaced (ill do that this weekend). I put MSD wires, ac delco iridium plugs, new front o2 sensors, cleaned out my radiator, had my fuel injectors cleaned and inspected all about 10-15k miles ago...i just had my transmission rebuilt, new torque converter and also a 3 rib 3.42 diff put in about 1500 miles ago. had the tune done by ECS.
I just dont know what is wrong. the car will tug or surge a little on decel or very light accel. im getting poor gas mileage as well...
only have 1 code
BCM-2723
i do have a small oil leak from the back of the engine as well.
