what shocks for drag racing?
Old Jan 31, 2011 | 11:43 PM
kboboz71's Avatar
kboboz71
Default what shocks for drag racing?
hey guys, im trying to find out what would be a good setup for street/strip drag racing. i have a h/c/i/e c6 z51 6sp manual. its making 500rwhp now and ill be adding a 150rwhp dry nitrous shot to it in the next few weeks. im getting alot of wheel hop with the nitto drag radials along with alot of tire spin... what is a good setup that will cure this that costs 1k or less... thanks in advance for all help..
Old Feb 1, 2011 | 07:54 AM
vsocks1's Avatar
vsocks1
Not sure you can cure this problem for $1000 or less. Some make special coil overs for drag racing but they will be more. QA1's may be under $1000 but not sure the shocks alone will solve all your problems unless you have other suspension upgrades. You may also need a stiff rear sway bar, trans brace & trans mount to name a few....
Old Feb 1, 2011 | 10:03 AM
Slow Z06's Avatar
Slow Z06
coil overs
Old Feb 1, 2011 | 10:11 AM
black98c5's Avatar
black98c5
For starters, ditch the Nitto's and get some M/T's.
Old Feb 1, 2011 | 01:22 PM
ZZOOM06's Avatar
ZZOOM06
2 of my friends that drag race their C5's regularly have had good luck using QA1's to cure their wheel hop problems. Having the adjustability to soften up the rear shocks makes a big difference.
I have '04 Z06 shocks on my car, but I run 16" bias-ply slicks at the track and I don't have any problems with wheel hop, but do plan on getting a set of QA1's if I find a good deal on a used set.
Jimbo
Old Feb 1, 2011 | 04:29 PM
vsocks1's Avatar
vsocks1
Jimbo
So in general don't you want to stiffen rear and soften front?
To what shocks for drag racing?
