Any felt difference after CAI mod
Old Feb 2, 2011 | 11:16 AM
cal45's Avatar
cal45
Default Any felt difference after CAI mod
Im aware most folks do the CAI mod while adding others at the same time. My question is just for folks that add the CAI as a stand alone mod - did you feel any difference before & after?
Old Feb 2, 2011 | 11:25 AM
Darion's Avatar
Darion
For me I feel that throttle response improved a bit, fells a bit quicker, more responsive. Nothing dramatic just better, I have a Calloway Honker btw.
Old Feb 2, 2011 | 11:40 AM
BitViper's Avatar
BitViper
Ditto...
SOTP dyno is good for these small changes.. Hp wise... less that what the Mfg advertises
Bottom line.. find one used Vs new.. or search out the "zip tie mod" and try that.. its about the same.. better throttle responce "seems peppier" nothing drastic
Old Feb 2, 2011 | 12:58 PM
Bluefire's Avatar
Bluefire
After my VaraRam install I immediately felt a difference in pulling strength as well as, I could hear the air being sucked in harder.Post tune was seriously more noticable.
Old Feb 2, 2011 | 01:54 PM
JaxC5's Avatar
JaxC5
I have the K&N CAI, sotp meter jumped some, DIC indicated better highway mpg's as well....
Old Feb 2, 2011 | 03:34 PM
Solofast's Avatar
Solofast
That statment is, quite simply, nonsense.
You need a certain amount of air to drive the car at highway speed. If you have less restriction in the air cleaner, or a bit cooler air going into the engine, you will have to close the throttle body a bit more to get the same airflow.
If the throttle isn't wide open, the amount of air cleaner restriction and air temp is meaningless. (assuming that the air going into the engine isn't really hot, which, it isn't since the stock air inlet is ahead of the radiator).
If you think you got better highway mileage, it was just wishful thinking, a tailwind, or a flatter piece of highway. It has nothing to do with the inlet, air cleaner or the restriction. If you think it was better, you are just kidding yourself.
Old Feb 2, 2011 | 05:23 PM
R CRYSIS's Avatar
R CRYSIS
Default Vararam
installing a vararam with the power duct was one of the first mods I made to my car and I could definitely tell a difference. The car was More responsive and pulled harder through the gears. Was it a mind blowing difference?..No but it does make a difference especially if you install other mods I have been racing my whole life so I am not impresses by all of the claims manufacturers make on there products until I see for myself but if you read the posts on this site you will see that most people say they can feel a difference with the Vararam
Old Feb 2, 2011 | 05:29 PM
YNOT2K's Avatar
YNOT2K
Originally Posted by Bluefire
...I could hear the air being sucked in harder...
this is the ONLY difference for me.
Old Feb 2, 2011 | 05:44 PM
hotwheels57's Avatar
hotwheels57
The wallet is usually a lot lighter. Less weight is almost as good as more horsepower. Most owners equate more intake noise with more power, which isn't necessarily accurate...
Old Feb 2, 2011 | 06:15 PM
R CRYSIS's Avatar
R CRYSIS
Default C.a.i
I agree but some C.A.I have been proven to work by 1/4 mile times before and after installation. Forum members have seen 1/4 mile times reduced by up to 3 tenths usually a tenth or two and an M.P.H or two by installing the Vararam unless they are all exaggerating which I doubt. The stock C5 air box leaves a lot to be desired . The C5 air box was modified to support the LS6 intake needs I doubt G.M changed it for no reason. Also if you look at the C5 it is basically drawing in hot air from the engine compartment especially at lower speeds. The vararam brings in fresh air from the front to the vehicle fresh pressurized air helps make horsepower. Like I said it's not like you just did a heads and cam package but in my opinion it's worth doing especially if you are going to do further upgrades I think I got the whole system with the power duct for 330 dollars...just my two cents
Old Feb 2, 2011 | 07:36 PM
hfddirty30's Avatar
hfddirty30
Before you go out and buy a CAI,I took the stock air box and drilled 1" holes with a hole saw.I drilled about 20 holes in the cover,I agree the increased air flow will only help at FULL throttle.Also added a smooth couple before the throttle body.Had the stock engine tuned,and it turned 325 RWHP.I could fell the difference at full throttle after the air box mod.My next step will be headers and exhaust.
Ed
Old Feb 2, 2011 | 09:49 PM
red oneee's Avatar
red oneee
Old Feb 3, 2011 | 07:20 AM
JaxC5's Avatar
JaxC5
You are right....it was probably all 4 things. I was kidding myself on a flatter piece of highway, being pushed by a tailwind while doing a ton of wishful thinking.
I was just sharing my experience. I drive from North Florida to South Carolina once a month and I have been doing that for 3 years. Prior to installing the CAI the DIC would display an average around 28 mpg, after the install the DIC displayed 30. I doubt I actually picked up 2mpg, if any at all.....just passing on an observation.
I did not buy it to get better gas mileage, I bought for the 140 rwhp I picked up after I bolted it on. < --- Wishful thinking and kidding myself again.....
Old Feb 3, 2011 | 08:09 AM
Solofast's Avatar
Solofast
At least you had realistic expectations for what a CAI could do...
Old Feb 3, 2011 | 08:25 AM
JaxC5's Avatar
JaxC5
Exactly...I figure if I drill some holes into the filter itself I will pick up some more power and a couple more mpg...
Old Feb 3, 2011 | 09:28 AM
rebelheart's Avatar
rebelheart
I went from a blackwing to a Vararam and my ET dropped from consistant 13.16's to consistant 12.92's.My MPG did drop a couple of MPG though.Throttle response was crisper and the drop in MPG may have been because it felt better to get on it!
Old Feb 3, 2011 | 11:47 AM
-98-z28-darkness-'s Avatar
-98-z28-darkness-
i just installed the K&N fipk II on a c5 2002. I was surprised that i felt a difference in throttle response was not expecting any. and it does sound nicer hearing the air sucked in lol. top end feel it pick up a bit but it may just be the sound lol.
overall it looks good and i know it will give me more power as i go modding other things exhaust, tune, ect
To Any felt difference after CAI mod
Old Feb 3, 2011 | 01:54 PM
rboineau's Avatar
rboineau
If you want most if not all of whatever performance improvement a cold air intake brings without spending much if any $, do this to your Coupe or Convertible. Remove the fog light housings and cut slots in the upper (horizontal) section, towards the center of the car. Use common sense in choosing the location/size of the slots and make sure you are not weakening or compromising any mounting tabs, etc. This mod is totally invisible from looking at the car; air at speed flows into the fog light housing recess, looks for a place to escape, and goes out the slots up into the airbox area. Yeah, there are still some obstructions but your airbox will get pretty much all the ambient air it can handle. Finish off by buying a used or new Z06 airbox cover--used are very cheap--and you've got cold air benefits without having to pay a lot of money(on some cold air systems) or struggle with crappy parts quality/fitment(on others).
Old Feb 6, 2011 | 10:12 AM
mcv's Avatar
mcv
To the OP, you do feel a difference after installing a Honker on a C5. Here's an article from Vette Magazine that reported on an independent test.
Old Feb 6, 2011 | 10:21 AM
kmetros's Avatar
kmetros
You're brain will tell you all kinds of crazy things after you have just spent $500. Not saying they don't work, just saying you can't really feel a CAI in the seat of the pants. I bought my Callaway Honker used. There's no way that little horse power is worth that much money (new cost), IMHO.
