New up date, on battery maintainer!!
Old Feb 3, 2011 | 08:13 PM
dbiddle's Avatar
dbiddle
Default New up date, on battery maintainer!!
OK, Took it off the EXT. cord and it took about 2 hrs, for the charger to show me a green light.
And took it off the charger and then checked it again, Now with not useing the EXT. cord. it now shows me on my gauge 12.73 Volts.
I will keep checking it now and then..but i sure hope its fixed now that i have it just going to the wall, with out any EXT. cord.
but man if i just open the car door for a sec, or open the hood and any of the little lights go on..even for a min. it seems to take this new charger back to the charge mode for about 1/2 hr to get it to show green full charge again.Man thats slow.
So what are your thoughts on this matter?..does it sound about right? Thanks, dbiddle.
Old Feb 3, 2011 | 08:47 PM
dbiddle's Avatar
dbiddle
Originally Posted by 8VETTE7
How are you checking the voltage? Reading the dash gages with the key in the on position but engine OFF? Or using a digital voltmeter directly across the battery posts with NO KEY in the ignition?
Im useing a digital volt meter directly across the battery post with NO key in the ignittion..am i doing it right.? with the maintainer not hooked up.
Its a brand new battery and maintainer.
Old Feb 4, 2011 | 02:26 PM
Oldvetter's Avatar
Oldvetter
A 12-volt battery will measure at about 12.9 volts when it’s fully charged and about 11.4 volts when it is fully discharged.
Old Feb 4, 2011 | 02:42 PM
Mr. Blue's Avatar
Mr. Blue
I have an Optima yellow top and I use a CTEK charger with it. I just wanted to let you know that I see the same thing - if I open the door for a few seconds and all the interior lights go on, the CTEK red light goes on and it takes a good while for it to go back to the red. It's been doing this forever and I never have a problem starting the car.
Old Feb 6, 2011 | 06:35 PM
ALLEGRO's Avatar
ALLEGRO
YUP
To New up date, on battery maintainer!!
