Help please.....Oil pressure issues
About 10 mo. ago, while crusing at 50 mph, the "check gauges" warning came on and it was followed by "low oil presure" warning. A quick look confirmed the message. I shut off the motor, coasted off the side of the road and I checked the oil level, finding it to be on the full mark, I restarted the motor and drove off. During the next 3-4 months the condition did not return and I finally wrote it off as a defective OPS unit. Then it happened again….same type of conditions; and again, when I restarted the motor the gauge functioned and everything returned to a “normal” state.
Last November (about 10 months from the initial problem occurrence) I replaced the cam, intake manifold, full exhaust system, and oil pump (ported and shimmed LS-6 pump from Texas Speed). I added a new OPS (remotely mounted) and added a mechanical OP gauge ahead of the sending unit. When the motor is cold, both the dash gauge, and the new mechanical gauge, read about 65psi at start…..after warming , the pressure drops to about 40psi under normal driving conditions.
Unfortunately, the same condition returned within about 50 mi after I put the car back on the street. Almost exactly the same as before I swapped parts in the motor. When the warning sounds, the dash gauge drops to almost nothing (10psi or less) while the mechanical gauge reads a little higher (around 15-20psi.). Both gauges recover and bounce back to around 40psi within about 10-15 sec.; but, they both still drop pressure..
There is not any pattern to when it occurs…. straight and level driving, no turning , no hard acceleration; but, it has happened at least 4 times in 400miles (since returning to the street). The motor is completely dry, does not consume oil (5w/30 Mobil 1), and does not make any unusual noise ( no lifter or oil starvation sounds); although I am watching closely and get the load off the motor within seconds of the warning….I am pretty sure the o-ring on the pick-up tube was correctly positioned and correctly installed.
This is frustrating and I am not looking forward to tearing down to replace the oil pump…again unless there is no other good options…..does anyone have any suggestions regarding the probable cause for this problem????
