Another Help With Trouble Codes
Old Feb 5, 2011 | 03:04 AM
ImBlackMomba's Avatar
ImBlackMomba
Default Another Help With Trouble Codes
So here's the story, Im in process of purchasing an 02 that have thrown the following. Im trying to figure out about what the cost is for each fix.
If anyone can give any help, please do.
Marcus
1296 – Brake Pressure Sensor / Master Cylinder Pressure Sensor Circuit
B2285 Battery #2 Circuit
B2287 Mirror Position Sensor Circuit
C1296 Master Cylinder Pressure Sensor Circuit
U1064 Loss of Communications with BCM
C1214 Sol Valve Relay Contact or Coil CKT Open
??Bad EBCM $150
C1294 Brake Lamp Switch Circuit Always Active
B2285 Battery #2 Fault
??Possible low battery or corroded terminal
B2287 +5V Reference Fault
U1016 Loss of Communication with PCM
Old Feb 5, 2011 | 03:11 AM
ZeeOSix's Avatar
ZeeOSix
Did you reset all those codes and look for resets? Can't believe any car can have that many issues going on. Some of those may be set from some other issue or code being set. Only way to know is to clear them all, drive the car and see if any DTCs come back.
Old Feb 5, 2011 | 11:41 PM
Bill Dearborn's Avatar
Bill Dearborn
C1296 – Brake Pressure Sensor / Master Cylinder Pressure Sensor Circuit
Sensor is on BPMV. There could be a short to ground or a low 5V reference signal to the sensor. There could still be an issue with the sensor itself or the EBCM. If it is the EBCM ABS Fixer will probably not be able to fix this issue. Can't just replace a relay to fix this.
Again something related to a potential low voltage issue.
One of the first tests performed in the diagnostic procedure for this code is to check the 5V ref signal. Again another voltage issue.
See above
??Bad EBCM $150
This could be a bad relay or just a low input voltage from the battery. If the relay is bad then you may be able to get it fixed.
Possible causes of this DTC are the following conditions:
The stop lamp switch circuit is shorted to voltage.
The stop lamp switch is misadjusted.
The stop lamp switch is stuck closed.
A brake pedal that is binding.
Both brake light bulbs are burned out.
??Possible low battery or corroded terminal. Yes, however, the diagnostic checks all of these potential problem areas:
The number(s) below refer to the step number(s) on the diagnostic table.
2. This test verifies if the vehicle's Starting/Charging system is functioning properly.
3. This test verifies if the door module is functioning properly.
6. This tests for a short to ground in the door lock actuator control circuits.
7. This tests for a short to ground in the heated mirror element supply voltage circuit.
8. This tests for a short to ground in the door lock actuator motor.
9. This tests for a short to ground in the mirror heater.
??Possible low battery[/quote]
I would start with checking the battery, the battery connections, and the wiring in the driver door accordian. When you get a bunch of issues like this it is usually battery related but not always. The going diagnostic philosphy is there is almost always only one problem that is causing everything. But that is almost always not always. You could still have an EBCM issue.
Bill
Old Feb 6, 2011 | 12:51 PM
ImBlackMomba
Thank you guys for the help in such a short notice. I took the car to a autozone before purchasing and the only codes present were C1214 and C1296. The only issues Ive experienced or can notice are:
- Pegged oil pressure gauge
From what Ive researched a new sending unit should fix the issue.
- Intermittent Service Active Handling
EBCM? I plan on having it rebuilt. Car drives and handles great for an 02 with 100,500 miles.
Here is what I sold...
Here's what I picked up.
02 M6, Corsa Exhaust, BlackWing Air Intake and the cowl hood.
To Another Help With Trouble Codes
