randy
Old Feb 5, 2011 | 02:28 PM
rslobodnik's Avatar
rslobodnik
Cruising
Default randy
Hello fellow corvette owners, does anyone out there know where I could find a Body control module for my 1999 corvette conv? my trunk release circuit does not work.
I am also looking for a used front bumper cover, I want to modify and build a mold for a different looking one.
Please help
thanks,
Randy
Old Feb 5, 2011 | 02:36 PM
hotwheels57's Avatar
hotwheels57
I thought you had a question for Randy...
Try Gene or Patrick at GMPARTSHOUSE (not GMPARTSDIRECT) for the module...
http://www.gmpartshouse.com/
Old Feb 5, 2011 | 02:42 PM
rslobodnik's Avatar
rslobodnik
Cruising
I thought title meant title of the person posting not the title of the Post itself.
Old Feb 5, 2011 | 02:46 PM
jrose7004's Avatar
jrose7004
Maybe Randy has it!
Old Feb 5, 2011 | 02:48 PM
hotwheels57
No, not normally. The title should draw attention of the reader what you're trying to accomplish.
You can click on "edit", then "go advanced" and I think you should be able to edit your title. Actually, this might be better posted in the classifieds section.
Old Feb 5, 2011 | 04:55 PM
dougbfresh's Avatar
dougbfresh
http://www.urbandictionary.com/define.php?term=randy
Old Feb 6, 2011 | 02:53 AM
DeeGee's Avatar
DeeGee
Changing the BCM because the trunk release doesn't work sounds a tad dramatic. Is that the only reason you need a BCM?
Dumb questions but
Have you checked the fuse (26 in the footwell)?
Are the connections tight behind the switch?
Is the latch release adjusted correctly?
Does the latch release operate when you hit the button?
Changing a BCM can cause quite a few knock on issues and isn't for the faint hearted
Old Feb 6, 2011 | 03:04 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Dumb questions but
HOLY CRAP! That was my thought exactly! You do know that you will have to do a BCM relearn to enable the BCM to communicate with the PCM and then have the RPO codes that go with your car programmed back into the new BCM with a TECH 2..
Are you SURE the BCM is at fault??????????
BC
Old Feb 6, 2011 | 09:00 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
As Bill was saying, if you replace the BCM, the car will NOT start up until you do the relearn procedure, then you'll need the Tech2. Look at the simple things first before going that route.
Old Feb 6, 2011 | 11:08 AM
rslobodnik's Avatar
rslobodnik
Cruising
Default Bcm
Thanks everyone for your help, I checked all wires and switches, in fact I now have a switch wired in parallel with the BCM module out put and the trunk release works that way, I was just hoping to be able to use the Key fob again. I also do realize that you would have to do the relearn. I thought if I could get a BCM cheap enough I could take to GM dealer to do the relearn.
thanks
Old Feb 6, 2011 | 12:31 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I still dont see why you think you have a BCM issue. Please list ALL your symptoms and what DTC are being diaplayed.
BC
Old Feb 6, 2011 | 01:38 PM
lucky131969's Avatar
lucky131969
BC
I'd like to know what this statement means: "I checked all wires and switches"
1) Did you check fuse #26 and fuse #32 in the passenger footwell?
2) Did you make sure pin C12 of connector C2 to the BCM is not grounded?
Old Feb 6, 2011 | 02:14 PM
rslobodnik's Avatar
rslobodnik
Cruising
Default Bcm
Again thanks for all of your help, I did check all the fuses and relays in the fuse block in the foot well, in fact I think that is what caused the problem in the first place. Last year my air conditioner filled up with water and leaked all over the BCM before I could get a chance to unplug the drain. I went to the web and got a manual for the car and proceded to check the wires and switches per the manual, that is how I determined that that was the problem. Of course now the car is all covered up waiting for some nice weather probably around April or May.
But I will definately take all of your advice and re-check items mentioned.
thanks
To randy
