ARP main studs-bolts
Old Feb 5, 2011 | 09:05 PM
GREG O.'s Avatar
GREG O.
Default ARP main studs-bolts
Does ARP make a main bearing bolt or stud kit for a 6.0 iron block that does not require any special maching or honing or windage tray problems...I was told by a builder he uses the stock 6.0 gm bolts on the mains since they are 6 bolt..and ARP would need machine work done.
Old Feb 6, 2011 | 12:55 AM
cantrelmitl's Avatar
cantrelmitl
St. Jude Donor '10
Not a builder, but it is my understanding that the higher torque specs of the ARP studs can possibly cause distortion in the main caps with the additional clamping force. I just did my 427 with ARP studs and went this route for insurance. Lots of writeups on using ARP studs on LS1 Tech. Also, take a look at Katech and Mast's site, pretty much all their high end engines use the ARP studs and do the align honing to ensure trueness after torquing the ARP studs. IMHO, wouldn't do the studs w/o doing a align hone. Good insurance in my mind so you can you can add power adders with confidence later down the road.
Mike C
Old Feb 6, 2011 | 01:44 AM
GREG O.'s Avatar
GREG O.
Mike C
thanks cantrellmitl.....i will do a search on the LS1 Tech....and read more ....i wonder if the ZR1 has stock GM bolts...i would think so...
again thanks GREG O.
Old Feb 6, 2011 | 10:01 AM
slow ride's Avatar
slow ride
Depends on what you are doing with the car. Stock main bolts will hold a lot of power. I've got ARP main studs and didn't need to line hone the block, but it's not always common. If I were to do it all over again I'd just use the stock bolts as they have held way more power than my car will ever put down.
Old Feb 6, 2011 | 02:54 PM
Z0600's Avatar
Z0600
According to my engine builder stock bolts are good for 1000 hp as my friend is prooving with his turbo 388. I agree studs have there place in race engines but with the LS platform having 6 bolt mains I think it's usually a un-needed upgrade for most people.
Old Feb 7, 2011 | 02:11 PM
GREG O.'s Avatar
GREG O.
thanks guys for the info.....
To ARP main studs-bolts
