LS1/LS6 Head bolt holes!
Old Feb 6, 2011 | 01:00 AM
LSX4LIFE's Avatar
LSX4LIFE
Default LS1/LS6 Head bolt holes!
Not sure but are the bolt holes for the heads on the ls1/ls6 engines blind holes or do they go in to coolant.
Old Feb 6, 2011 | 03:01 AM
zeevette's Avatar
zeevette
They don't go through coolant, but when you take the heads off, some coolant splashes into the holes. Make damn sure the threads/bottom of those are clean before you replace them. Factory bolts are TTY, one time use only. Spring for ARP bolts, or studs, and you can reuse.
Old Feb 6, 2011 | 03:09 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
BLIND HOLES!!! If you leave ANY and I repeat ANY coolant in the holes you run the chance of rupturing th block due to hydro-locking the coolant in the holes. It will break the block. Make sure there dry before installing the bolts!
Old Feb 6, 2011 | 11:57 PM
LSX4LIFE's Avatar
LSX4LIFE
thanks guys for the help
Old Feb 7, 2011 | 01:39 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Here's a couple tips:
1) rolling up papertowel like a cigarette you can snake into the holes, when the paper comes out wet, just cut off the wet part and you can go again. I usually get about 2-3 dips into the hole on each sheet.
2) take one of your OLD head bolts and grind off one or two sides of the threads.... and use it like a tap to chase out the holes in the block. You'll be suprised how much gunk is in the threads!
3) don't forget to razor off the carbon from the piston tops while you're there.
Take your time... it's kinda tedious. Beer helps.
To LS1/LS6 Head bolt holes!
