Thanks for the input but that doesn't answer the question.........
Originally Posted by 8VETTE7
What happens/where does the coolant go if the expanded coolant requires more space that exists in the surge tank?
The tank is designed to be able to take all the expansion IF you have the level adjusted correctly in the first place, like I've described above.
If the coolant gets any hotter to cause the tank to fill it's volume completely when it was originally adjusted correctly, then you're gonna have bells and whistles and gauges pegged telling you to stop driving!
If you fill it too full and get it too hot, then I think hot coolant is going to puke out the pressure cap. Remember, it vents to ATM to maintain the correct pressure in the system.
Make sure the level is correct when the coolant is cold and you will never have a problem.
Yes, it will puke out of the pressure cap if it is filled to full. I have never had an issue with the system being too full in 14 years of owning C5s and C6s.
The pressure cap is designed to release excessive cooling system pressure. It will also eliminate overfilled coolant as well, if the system pressure exceeds 18 PSI, with the surge tank in an overfilled condition.
