Shifting ill's
Old Feb 10, 2011 | 03:14 PM
MisterC's Avatar
MisterC
Default Shifting ill's
I managed to whack my 6 spd transmission not too long ago and had it rebuilt at a reputable, well known Corvette tuner. After several arrempts I finally accepted it but now have some regrets. It just will not go into 5th gear without a fight. Now thinking perhaps a new transmission is the only answer, BUT, I'm wondering if the whole problem may be external to the transmission. I'm not real familiar with how it all works, but is there rods that run from the shifter back to the transmission? Could a bent rod affect just 5th gear while not affecting any other shift? The originaldamage was the 5th gear slider.
Thanks for any advice or help.
Old Feb 10, 2011 | 03:18 PM
lucky131969's Avatar
lucky131969
So the original damage was the 5th gear slider, and you still have problems with 5th gear. What does the shop have to say about this?
Old Feb 10, 2011 | 03:28 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
C
The C5 & C6 transmission is shifted via a single shift rod that runs from the shifter box thru the torque tube and to the shift rod input to the rear mounted transmission. ALL the shift gates and shifter return springs are INSIDE the transmission.
Inside the shift box is single ROD with a hole in the center of the rod. The shifter stick moves that rod FORWARD & REVERSE AND ROTATES IT SIDE TO SIDE.
There is a shifter alignment procedure in the service manual. You also need to inspect the rubber bushings that isolate the shift box from the torque tube. They deteriorate and can caues shifting issues. Sad part, GM does not sell them seperately. Theres a guy on the C6 forum who makes a suitable replacement.
What shifter do you have????? STOCK or Aftermarket
I will send you some picts of this stuff later tonight:
BC
Old Feb 10, 2011 | 03:31 PM
MisterC's Avatar
MisterC
Well, they sent me out the door knowing that it had a problem and I conceded that they couldn't fix it. The comment was 'there's nothing more we can do except get a RPM transmission'. I already had quite a bit of money into it so I was hopeful (how dumb) that I would just learn to finesse it into 5th gear, and I could for a while, but now it's getting harder to live with. That's when I started thinking that it may be a linkage problem more than a transmission problem.
Old Feb 10, 2011 | 03:38 PM
lucky131969
Ok, there is only a single rod, from the shifter to the tranny. If the shop acknowledged they could not fix the trans, why do you think it's a problem with the rod. What EXACTLY was wrong, that was beyond repair, by a competent shop. I'm confused...
I guess you should also clarify what it means to "whack" the transmission...
Old Feb 10, 2011 | 03:40 PM
MisterC's Avatar
MisterC
Thanks Bill, I appreciate your interest. It's a MGW shifter.
Old Feb 10, 2011 | 03:46 PM
MisterC's Avatar
MisterC
You are undoubtedly aware of the clutch problems of the C5. I was at the track and when I came off the line, the clutch pedal would not return. I stopped the car and put it in neutral, then re-engaged the stuck clutch to find a gear so that I could clear the track. I believe that stabbing the shift lever from gear to gear trying to get into any gear did (a) knock down three teeth on the big end of the slider, and (b) possibly bend the shift rod. If they indeed replaced the gear, which I have no reason to doubt, and it still don't work right, could the rod be bent?
Old Feb 10, 2011 | 03:51 PM
lucky131969
To answer your question. Is it possible that the rod is bent, yes....is it probable....no. Additionally, for the rod to be bent, and only affect 5 gear is a stretch. Again, you originally had a problem with 5th gear only, and you still have a problem with 5th gear ONLY.
You have not answered the most important question: What EXACTLY was wrong, that was beyond repair, by a competent shop. Why was replacement the only option presented?
Old Feb 10, 2011 | 04:04 PM
MisterC's Avatar
MisterC
I don't have an answer for that, Lucky. The problem with the transmission was that it would grind badly going into 5th. After several attempts by the techs, it would go into 5th with some very light-fingered ****ing technique. It seems harder now than when I first retrieved the car from the shop.
Old Feb 10, 2011 | 04:08 PM
lucky131969
It's kind of hard to help, without that info. When the only suggestion is "buy an RPM transmission", it makes me wonder. Did they just not want to fix it.? were not capable of fixing it?.....or just wanted to sell you a transmission? Sounds like you need to get it to a trusted shop. Who did the work?
Old Feb 10, 2011 | 04:15 PM
MisterC's Avatar
MisterC
Thanks for your interest Lucky. I won't say who it was because except for my particular case their reputation is extremely good.
Old Feb 10, 2011 | 07:13 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
"their reputation is extremely good" It CANT be that good cause they sure dissed you! For someone whos suppose to have that good of a reputation, they should have been all over your issue. Its a mechanical gear box. If they cant disassemble it and figure ot what is not functioning properly, I SURE dont want them working on my stuff!!!!
If it were me, I would tell them to FIX IT or pay the price.
Sorry for the rant but I hate business that do people wrong like that!
Here are the pictures I promisse you:
Alignment Pin inserted :
Stock Shifter and a KIBAN:
Inside the Box:
The top shaft on the tranny is the shift rod attachment point:
Old Feb 10, 2011 | 07:20 PM
MisterC's Avatar
MisterC
Thanks very much for the pix. They are certainly helpful to me to understand the mechanics of shifting.
Old Feb 11, 2011 | 10:07 AM
hornet7's Avatar
hornet7
Default shifter alignment procedure
Hi Bill, I have a Manual on DVD but it's not happy at this time. Can you post the shifter alignment procedure?
Originally Posted by Bill Curlee
C
BC
Old Feb 11, 2011 | 04:21 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Robert:
I knew I had seen this somewhere before.
http://rpmtransmissions.com/files/c5...adjustment.pdf
Hope you get it figured out !
Toque
Old Feb 11, 2011 | 05:19 PM
MisterC's Avatar
MisterC
Originally Posted by Toque
Robert:
Toque
Thanks Toque!
Old Feb 12, 2011 | 05:19 PM
ragtopws6's Avatar
ragtopws6
I'll give you my $0.02 since I build these on a regular bases. If you ONLY had an issue grinding going into 5th gear, it would have been most likely the broken plastic fork pads. Also, if the 5th gear grinded for a while, the corresponding synchronizer (5-6 synchro) has to be replaced also since they interlock. If you have the invoice, see if the 5th gear and 5-6 synchro was replaced. If not, that is the culprit.
I have NEVER seen a bent rod by the way.
To Shifting ill's
