Under Hood Lamp, Help.
Old Apr 12, 2002 | 02:27 AM
TexCorvette's Avatar
TexCorvette
St. Jude Contributor
Default Under Hood Lamp, Help.
It doesn't work. Which fuse is for it? Likely its just the bulb, what type do I need and does that cover come off easy without bracking? Sure could have used that light when I needed to change my battery in the dark today.
Old Apr 12, 2002 | 07:57 AM
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Under Hood Lamp, Help. (TexCorvette)
The little plastic cover comes off. You simply need to squeeze it a little and it will pull off. Jiggle the bulb..........it may just be loose. Better yet, hook a tester light to it and see if you're getting power to the bulb. If you are, you have a bad bulb, if not, you have a blown fuse.
Old Apr 12, 2002 | 09:32 AM
MVP's Avatar
MVP
Default Re: Under Hood Lamp, Help. (Mag Red Monster)
Check to see if the blue connector is connected. My dealer always removes this when working on the car so that the light doesn't stay on. The blue connector is locataed at the front passenger side of the car. You will see a wire with the blue connectors in the middle of no where on top of/next to the radiator shroud. Hope this helps if this is the problem.
Old Apr 12, 2002 | 12:11 PM
lostsoulny's Avatar
lostsoulny
Default Re: Under Hood Lamp, Help. (MVP)
bulb is around 5 bucks at your local auto store pop it in and you are good to go.
Old Apr 12, 2002 | 02:43 PM
AZ99FRC's Avatar
AZ99FRC
...Sure could have used that light when I needed to change my battery in the dark today.
Hmmm, I don't think it's ever gonna work during that job! :D
Old Apr 12, 2002 | 03:01 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
It's not necessary to disconnect. The computer monitors that circuit and turns the light off after 5 minutes. Maybe your dealer thought he was working on a Cavalier ?? :D
Old Apr 12, 2002 | 06:03 PM
TexCorvette
Default Re: Under Hood Lamp, Help. (need-for-speed)
Hehe, good point AZ99FRC. Of course when the battery is out it won't work, But I mean it would have heled to see things while it was conectect, and while tightning the posts on the new one and such. Have a flash light for the time inbetween.
Old Apr 14, 2002 | 07:00 AM
TexCorvette
Anyone else have input?
To Under Hood Lamp, Help.
