2004 GTO engine for parts?
Old Feb 14, 2011 | 11:13 AM
FBeitel's Avatar
FBeitel
Default 2004 GTO engine for parts?
I have the opportunity to buy a engine out of a 2004 gto that the local dealership replaced because of excessive metal in the oil. It has 243 heads, my question is would it have a ls6 intake and block? If it does have a ls6 intake is it the same as a covette intake. This engine also has a texas speeds cam in it I will find out which one today.
Old Feb 14, 2011 | 04:19 PM
4SFED Z's Avatar
4SFED Z
Ls2 block and heads. If they are replacing, why are you buying? Better find out the cause of metal in oil before squezzing that trigger.
Old Feb 14, 2011 | 04:44 PM
TNRAT's Avatar
TNRAT
Are you wanting to sell the intake?
Old Feb 14, 2011 | 08:41 PM
FBeitel's Avatar
FBeitel
I thougth 243 heads were ls6 heads? and I'm buying it for parts and the intake provided it is a ls6 intake? Trust me it is cheap. Also this motor has been torn down and My friend that works there said the cam looked perfect he figured it was bearing material but said even they looked ok.
Old Feb 14, 2011 | 08:45 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Edit:I was wrong....
Old Feb 14, 2011 | 08:46 PM
f6john's Avatar
f6john
I thought all the 04 GTO's were 350 hp ls1 engines. The 400 hp rating didn't show up until 05 right?
Old Feb 14, 2011 | 08:52 PM
0331MARINE's Avatar
0331MARINE
You sir are correct.
Old Feb 14, 2011 | 08:54 PM
lucky131969's Avatar
lucky131969
243's could be LS6 or LS2, just different valves. If it's a screaming deal...buy it......
Old Feb 14, 2011 | 09:16 PM
FBeitel's Avatar
FBeitel
I would say 325 is a pretty good deal. So are the heads not factory to the car? If not I would guess that they have work done to them I know I was told they do not have factory springs or pushrods. What intake would this car come with an ls2?
Old Feb 14, 2011 | 09:18 PM
FBeitel's Avatar
FBeitel
My friend said that the reson they are putting in a crate motor and trans is because they took the car in on trade and it turned out to have a cooked clutch and some metallic in the oil and the dealer does not want to sell a non stock car.
Old Feb 14, 2011 | 09:21 PM
lucky131969
The heads alone are worth that.
Old Feb 15, 2011 | 12:22 PM
4SFED Z's Avatar
4SFED Z
They are. I meant ls2 intake
Old Feb 15, 2011 | 12:27 PM
FBeitel's Avatar
FBeitel
So if it is an ls2 intake would that be worth putting on my ls1?
Old Feb 15, 2011 | 02:08 PM
mAydAy121's Avatar
mAydAy121
St. Jude Donor '10
For $325 I'd buy it, the block is worth that...
To 2004 GTO engine for parts?
