Drivers side window stuck halfway down!
Old Feb 16, 2011 | 01:11 PM
topkart43's Avatar
topkart43
Default Drivers side window stuck halfway down!
Yesturday my driver side window got stuck halfway down. I took the door panel off and reconnected the window switch and it rolled up and down just fine. The motor did tend to make a weird sound as I was rolling it up. So I put the door panel back on and then today I went to roll my window down and now its stuck in the halfway up position. I took the door panel off again today and nothing. I can hear the click noise when I push the roll down button. I took the speakers off and tried tapping the window motor and nothing all I hear is the click noise. I don't know if I have a bad connection somewhere or if my motor is going out. I was wondering how hard it is to replace the motor or anything else that I might need to replace? The passenger window and door locks all work fine off the driver side switch.
Thanks,
Matt
Old Feb 16, 2011 | 01:15 PM
00Corvette's Avatar
00Corvette
Your motor/regulator is more than likely done.
I'd just order a new one or start looking in the F.S. section/ebay
Old Feb 16, 2011 | 01:23 PM
topkart43's Avatar
topkart43
Is there a write up on how to replace the motor?
Old Feb 16, 2011 | 05:47 PM
topkart43's Avatar
topkart43
ttt
Old Feb 16, 2011 | 06:30 PM
Cratecruncher's Avatar
Cratecruncher
When you heard the "weird noise" it was the sound of the cable tangling up on the spool inside the motor case. It happens when the white plastic spring guide breaks and allows slack in the cable. The reason it no longer goes up all the way is because the cable is now caught in the spool by another loop. I agree with 00Corvette. You need to replace the entire regulator assembly. Currently, there is no way to rebuild them. The good news is that its not that hard to replace and new units are still easy to locate.
Check the FSM for r&r instructions. It's good.
To Drivers side window stuck halfway down!
