Ok today i noticed when hittin the pedal, exhaust has a rattle...an also when i lift off pedal,slowing down...is this coming from those springs that hold h pipe up??? This is an a4 an its gettin on my nerves didnt notice it till i lowered car bout half inch all way round....car has stock exhaust with muffler delete...any help be great thanks.....
Removing the mufflers(I'm assuming you are running straight pipe) reduces a lot of mass, which could help dampen vibration. As you already stated, check the spring hangers at the rear bell housing. Also check the welds on the h-pipe. You'll just have to get under the car, and do some poking around.
While you have the car up in the air checking, be sure to look at the cats. If the substrate is breaking up, it can make a lot of noise. Give each cat a good tap with a rubber mallet, you will hear the insides bouncing around if they are bad.
Ok thanks guys will check this out tonight,car runs awesome pulls hard...but as stated didnt hear til was lowered...so who knows just my luck lol,an the stock h pipes jingle???
Some have had a noise that went away after replacing their stock H-pipe..
I would take a look at all the other stuff mentioned first
