MGW shifter question?
Old Feb 17, 2011 | 02:06 AM
El original's Avatar
El original
Default MGW shifter question?
Just purchased MGW shifter...well quality fantastic. Q. I have not installed it yet and while admiring it, I am asking myself how does it center itself in neutral gate or for that matter not just stay below whatever gear it was in when putting it in the neutral gate?
Shifter is not spring loaded and stays in any position left in. I have no experience with any shifter leave alone stock or MGW. I would think it should be spring loaded to center it in neutral gate. Hope you understand my question. Rob
Old Feb 17, 2011 | 09:19 AM
MGW George's Avatar
0MGW George
Former Vendor
St. Jude Donor '08-'11
the centering is done with the internal springs in the transmission. the factory shifter is not spring loaded either.
the springs are already heavy by most people's opinion on a corvette. added springs are overkill and make the shifter too hard to move.
george
Old Feb 17, 2011 | 03:33 PM
steponc's Avatar
steponc
St. Jude Donor '14
Default Adjustment
During the installation it is important to check the shifter to transmission oreintation. With the shifter in neutral the alignment hole on the front of the shifter box housing should line up with the hole in the shaft. This can be checked with the pin from your stock shifter. (a 90* pin) If the pin is not available you can use the shank of a 5/32" drill bit. Make sure when the pin is installed that the shifter cannot be moved in either direction. The pin can be installed in the housing but beyond the shaft. This allows the shaft to move in the direction of first gear but not beyond neutral in the direction of second gear. This adjustment if necessary, is accomplished by loosening the shifter housing, adjusting the position to neutral by moving the housing and then tightening done the housing slowly with the pin installed. Another bit of information is to carefully tigten the shifter down and keep it as square as possible.
My experience with this is having to pull a new transmission to have first gear worked on because first gear was not fully engaged and began popping out of gear, even under load. The transmission was installed by a reputable shop but they did not accept the responsibilty of their mistake.
Old Feb 18, 2011 | 03:22 PM
El original
Thankyou GEORGE and Steponc for your replys. Now if I don't touch the shifter box I should be able to drop in the MGW shifter and be good to go, right? --- I will remove the shifter box and replace shifter bushings which are probably worn. Then I will re install and check the shifter to transmission orientation.--- While on the topic and if you read this George..maybe you could in the future think of supplying shifter bushings with your kit, just a thought just add in the cost. Greetings, Rob
To MGW shifter question?
