Is heat a problem with headers???
Old Feb 20, 2011 | 07:21 PM
TN Vette's Avatar
TN Vette
Originally Posted by imavettegirl
probably you.
Bye Bye...
Old Feb 20, 2011 | 07:42 PM
imavettegirl's Avatar
imavettegirl
where are you going?
Old Feb 20, 2011 | 07:46 PM
lionelhutz's Avatar
lionelhutz
Originally Posted by DarkSpeed
I was wondering the same thing...
Soon I'll be getting the XS-Power longtube headers, and I've heard that headers dissipate more heat into the engine bay, with the spark plug wires next to each cylinder bank I'm kinda worried as well...
Anyone with longtubes have any experience? maybe some sort of heat-shield needs to be used? Thanks
So far with the XSpower headers the side of the #3 boot is about 1/8" away from the tube. I'll probably try it, it's right at the end of the boot. But then I might grab some sleeving and cover it before I start driving. The problem is the sleeving will touch and the heat might transfer better when it's touching and still melt it.
Not sure on the passenger side since I only quickly bolted it up and found the AC line touching before I dropped it again to re-install the starter. I put a clamp on the frame to the hard line coming from the compressor and pulled it over so the A/C line is harder against the frame and that gave it a little clearance.
Peter
Old Feb 20, 2011 | 07:53 PM
imavettegirl
my kooks have no problems heating or burning anything.
Old Feb 20, 2011 | 11:24 PM
motogib1's Avatar
motogib1
I haven't heard of too many problems from the heat coming of headers. You can always get the headers ceramic coated. this is what I did.
Old Feb 21, 2011 | 12:41 AM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
Originally Posted by lionelhutz
As the OP has asked, it would be nice to know opinions on how close the wires can be without melting. I'd think 2" to 3" without shielding would be OK. I'm looking at my AC line being about 1/4" from the header and even with the wrapping I'm worried about it.
FYI to anyone here. Go to your UserCP, click the Edit Ignore List from the items on the left and just add the idiots you want to block there. imavettegirl has managed to be the second member here I've blocked.
Peter
Originally Posted by C5XTASY
I'd recommend Kool Sox on your plug wires.
Ed
thanks for the good advice guys ALL of this info is helpful since I have a set of dynatechs to go in. cant wait for spring
Old Feb 23, 2011 | 07:04 PM
The Boy Racer's Avatar
The Boy Racer
Originally Posted by The Boy Racer
With my LG Pro Headers, they cooked everything not protected, including my Wide Band Controller. And it was over near the battery!!
Forgot to add that I bought a really nice set of wire protectors and this has solved my heat issues so far (1yr+).
Old Mar 1, 2011 | 02:06 AM
sbadd99's Avatar
sbadd99
its a good idea to shield you starter anyway, I had my headers coated but still made a shield as its even worse with RHD with booster etc all going over to the right side leaves little room.
Old Mar 1, 2011 | 10:35 PM
01vetter's Avatar
01vetter
I have ARHs jet Hot Extreme coated. No problems so far!
Old Mar 2, 2011 | 03:02 PM
SaberD's Avatar
SaberD
Ed
you can also get fiberglass insulation like this to wrap around anything you please to protect from heat.
