Is heat a problem with headers???
Old Feb 17, 2011 | 02:57 AM
dc491's Avatar
dc491
Default Is heat a problem with headers???
I have a 98 C5 and I just installed a set of Kooks 1 3/4" headers. The passenger side header is very close to the starter and other wiring. I am wondering if this is becomes a problem and if it does how do I heat shield it. I zip tied all wires away from the passenger side header, but how close is too close. The closest thing to the header is the AC line that is almost touching the headerbut has heat shield on it. What should be my concerns with this install?
Old Feb 17, 2011 | 07:39 AM
AU N EGL's Avatar
AU N EGL
Those plastic zip ties will melt, if that is a heat indication.
Old Feb 17, 2011 | 09:02 AM
dougbfresh's Avatar
dougbfresh
They used to sell heat shield for GM starters-try Summit or Jegs see if they still make them.
Old Feb 19, 2011 | 01:14 AM
sbadd99's Avatar
sbadd99
heat soak can be a issue with long tubes, its a good idea to shield the starter if you can now get to it.
Old Feb 19, 2011 | 01:40 AM
TNRAT's Avatar
TNRAT
The starter wires on the Viper truck I owned melted from the heat the shorty headers put out...wrap the wires with foil or better yet have your headers coated..
Old Feb 19, 2011 | 10:36 AM
imavettegirl's Avatar
imavettegirl
only if you touch them.
Old Feb 19, 2011 | 01:46 PM
TN Vette's Avatar
TN Vette
This is the same type of unhelpful comment I was refering to in the other header thread you posted in.
OP:
Check the clearances between the headers and wiring and make sure that you have as much air gap as possible. If you can buy or borrow an infrared thermometer with a laser pointer, that might help you identify hot spots that will need shielding.
Depending on how the primaries are routed, you might want to buy a starter shield for cheap insurance.
Old Feb 19, 2011 | 01:58 PM
lucky131969's Avatar
lucky131969
Yeah, unhelpful......but at some point, a little common sense has to be used. Considering the headers are the hottest part of the engine, second to the combustion chambers, protecting anything within close proximity.....should go without saying. Heat kills electrical components, wiring, connectors, etc.
Old Feb 19, 2011 | 02:18 PM
TN Vette's Avatar
TN Vette
agreed,
but a lot of the questions asked on the forum are legitimate especially if the OP has never performed a certain mod and is asking advice from those who have.
Old Feb 19, 2011 | 02:33 PM
imavettegirl
don't read my posts.
hope that was helpful.
Old Feb 19, 2011 | 02:34 PM
TN Vette's Avatar
TN Vette
That actually was. Thank you.
Old Feb 19, 2011 | 03:15 PM
imavettegirl
you are welcome. :lo l:: leaving:
Old Feb 20, 2011 | 03:15 AM
The Boy Racer's Avatar
The Boy Racer
With my LG Pro Headers, they cooked everything not protected, including my Wide Band Controller. And it was over near the battery!!
Old Feb 20, 2011 | 06:39 PM
lionelhutz's Avatar
lionelhutz
As the OP has asked, it would be nice to know opinions on how close the wires can be without melting. I'd think 2" to 3" without shielding would be OK. I'm looking at my AC line being about 1/4" from the header and even with the wrapping I'm worried about it.
FYI to anyone here. Go to your UserCP, click the Edit Ignore List from the items on the left and just add the idiots you want to block there. imavettegirl has managed to be the second member here I've blocked.
Peter
Old Feb 20, 2011 | 06:51 PM
DarkSpeed's Avatar
DarkSpeed
Default re: melting wires
I was wondering the same thing...
Soon I'll be getting the XS-Power longtube headers, and I've heard that headers dissipate more heat into the engine bay, with the spark plug wires next to each cylinder bank I'm kinda worried as well...
Anyone with longtubes have any experience? maybe some sort of heat-shield needs to be used? Thanks
Old Feb 20, 2011 | 06:53 PM
C5XTASY's Avatar
C5XTASY
I'd recommend Kool Sox on your plug wires.
Ed
Old Feb 20, 2011 | 07:01 PM
DarkSpeed's Avatar
DarkSpeed
Ed
Thank you sir, I'll check them out.
Better to be safe than sorry
To Is heat a problem with headers???
Old Feb 20, 2011 | 07:05 PM
TN Vette's Avatar
TN Vette
Peter
Who's the first?
Old Feb 20, 2011 | 07:14 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Jet-hot
Old Feb 20, 2011 | 07:18 PM
imavettegirl
Who's the first?
probably you.
