FOB & trunk unlatching issue
Old Feb 20, 2011 | 02:36 PM
kingrobby25's Avatar
kingrobby25
Default FOB & trunk unlatching issue
So my trunk will only pop open with the FOB if the FOB is right by the gas filler door. Will not work anywhere else, back, front, passenger side, etc. Put a new battery in it last night and synched it up and still the exact same problem. Does this with both FOB's. Thoughts?
Old Feb 20, 2011 | 08:29 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
The RF (Controller) is located by the gas tank. My bet is your RF controller is going bad.
Old Feb 20, 2011 | 10:53 PM
kingrobby25
Would that also explain why my doors like to unlock/lock on there own sometimes? Anyone know a way to test if this is really the problem?
Old Feb 21, 2011 | 07:19 AM
lucky131969's Avatar
lucky131969
Probably have the passive switch set to "on"......check your FOB.
Old Feb 21, 2011 | 09:37 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
What year is your car ? Passive key fob was 97 -99. Which could explain why your door locks are acting funny. Typically if you have you horn set to "On" when you lock the car you should here a beep when this occurs.
Old Feb 21, 2011 | 01:49 PM
kingrobby25
I can guarantee that the FOB isn't set to the passive mode, looking at it right now. I used it for about 1 week when I first got the car and didn't like it so have had it off since then.
Old Feb 21, 2011 | 01:51 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Some of the fobs are known to have bad solder joints that can cause similar problems.
Maybe a Tech2 could help pinpoint your problem.
To FOB & trunk unlatching issue
