powerloader question?
Old Apr 12, 2002 | 07:16 PM
'02'BlackC5's Avatar
'02'BlackC5
4th Gear
Default powerloader question?
Was wondering what kind of power improvement and 1/4 mile times or reduction in time I might see. I have a 2002 A4 2.73 gears, also have a vortex on the car now.
Old Apr 12, 2002 | 08:53 PM
Mitch C's Avatar
Mitch C
Default Re: powerloader question? ('02'BlackC5)
With the Powerloader you might pickup 1 or maybe 2 tenths. But you would get a much bigger improvement if you went with 3.42s and a converter.
98 A4
Powerloaded
Donaldson Blackwing
172 t.stat
Pro Torque 2400
3.42 gears
Old Apr 12, 2002 | 11:15 PM
'02'BlackC5
4th Gear
Default Re: powerloader question? (Mitch C)
Would you say that the powerloader and the 2.73 gears is as good in the 1/4 mile as just having the 3.15 gears and no powerloader.
Old Apr 13, 2002 | 03:50 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
On the dyno, I lost 1hp and 2 lbs of tq going from 2.73 to 3.42's. Never got to run the quarter with the 2.73's! But that was a long time ago, now great thing to come, hopefully. The powerloader was first installed with the 2.73's and updated with the 3.43's, I dynoed at 308rwhp!
Old Apr 13, 2002 | 10:27 PM
Mystery Fan's Avatar
Mystery Fan
I think the biggest gain you get from the powerloader is losing the torque management on the tranny and improved shifting. Your result on a 2.73 may not be as good but, I believe the improvement would be similar. See sig.
Old Apr 14, 2002 | 02:45 AM
'02'BlackC5
4th Gear
Default Re: powerloader question? (Mystery Fan)
Thats cool I hope to turn some 13.0's or 12's would be great! :cheers:
Old Apr 15, 2002 | 05:07 AM
Branden Mardis's Avatar
Branden Mardis
Hey buddy...
I have the same setup as you do. There is a track at the Corvette Museum and I ran 13.6's with the Vortex system complete. After I finally got the "Powerloader" and a larger throttle body from Breathless Performance...my best times were 13.2's. So, that's the numbers. Although there are an assortment of factors that affect the numbers. Yesterday my best times were 13.4's...but I was not hitting the tree good. I would say it is a great improvement...I noticed the car felt different, significantly different, right away...
Old Apr 15, 2002 | 08:15 AM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
You really need to replace the 2.73's. The PL helps, but the rear just won't get you where you want. Get 3.42's!!
Old Apr 15, 2002 | 11:20 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
The Powerloader will slightly adjust your Air/Fuel ratios for your Cold Air intake which could make a bit more power, as well as it backs off the torque management that GM programmed into your PCM to stop wheelspin between shifts, and it will do some amazing things with your shift points and shift firmness. I believe the transmission management part of the Powerloader is most impressive. Most A4 guys after being Powerloaded feel like they are driving a totally different car because of how the transmission is controlled by the Powerloaded PCM.
Horspower wise you are probably looking at gains of anywhere from 5 to 10rwhp. It is the changes made to the transmission management that offer the bigest performance gains.
If you are interested in any more details about the Powerloader, including pricing or ordering one, drop me an email.
Old Apr 16, 2002 | 12:31 AM
'02'BlackC5
4th Gear
Default Re: powerloader question? (Branden Mardis)
Thanks for the responses on this. So you guys think maybe 13.2's with the PL II. I would like flat 13.0's if possible. I will probably get the gears and TC, also isnt 13.6's about what the car will run completely stock with the 2.73 gears. If I am wrong can some one please tell me. I would like to know were I can get the GM 1/4 mile times on the different corvettes with different gears for 2002. :)
[Modified by '02'BlackC5, 4:32 AM 4/16/2002]
Old Apr 16, 2002 | 09:10 AM
Sully C5's Avatar
Sully C5
I can't find 2002 specific 1/4 mile times, however, for the coupe & vert '01 & '02 are the same, so here are the '01 times... http://www.corvettemuseum.com/specs/...erformance.htm
To powerloader question?
